DATE:
19th June 2011 (its a sunday!!)
WHERE TO MEET (sunny coast people)
BEERWAH HOTEL
53 BEERWAH PARADE
BEERWAH
11 AM FOR A 1130 LEAVE.
WHERE TO MEET (Brissy people)
BP CABOOLTURE - (TWIN BP's) NTH BOUND
BRUCE HWY
CABOOLTURE
1000 FOR A 1030 LEAVE
WHERE ARE WE GOING??
this will take in beerwah, peachchester , Bald Knob , Maleny , Balmoral Ridge , Montville and finally lunch at the palmwoods pub.
there will be a break point or two along the way for all of us to talk and compare cars.
the roads are clear and fun with a lot of uphill/downhill and turns. some will challenge you and some you will need your head screwed on for. no stupidity on the day.
the OFFICIAL route will be disclosed on the day by me
WARNINGS
for this run WE WILL USE UHF RADIOS!!! a small handheld is fine and the channel will be set on the day. if any one has a 5w handheld - bring it.
the run at Montville is a STEEP DOWNHILL run so make sure you have brakes. I did it in my van without issue and had a blast doing it take this as a word of warning.
all road rules apply
CONDUCT
Any stupidity and you will have myself and the rest of the club members to deal with. its a social cruise day. if you bring a mate please explain this to them. we are a club and anything that goes bad or stupid behavior reflects on the club and everyone in it.
IN ENGLISH
ACT LIKE A TOOL AND YOU WILL BE TREATED AS ONE!
COMMON SENSE PREVAILS. IF YOU LACK THAT - DON'T COME.
Now with all that aside - who's coming ??
(some one needs to pick me up :) )
  • Replies 43
im in
btw is the palmwoods road open again, was closed last time i tryed to drive it, would have been a while ago tho...
nope closed at montville. both of us made the turn into a BIG road closed sign today.
DAN,
added. I'll do the running total on SAUQLD.
JOHN,
done - pick me up.
what you doing to it?
Hey Dan, I had the coupe in for dyno tuning only to discover we had a big crack on the exhaust manifold as well as a blown wastegate gasket. Got the cracks welded up & a set of new gaskets so just need to put it all back together before getting it back over to EFI. My son & I are heading down to Sydney to watch the World Time Attack Challenge in August so for the moment I am just chasing a reliable tune. I have however been speaking to Rick about opening it up (internals have never been touched) & building up a strong HP RB20 in the next 12months. Having just resigned from my job this wont be happening in the immediate future but I really want to retain the heritage of the 31, & with so many people doing 25's, 26's 25/30's etc I just dont wont to "follow the pack". Rick showed me one of his customers R32 running a 2.2 stroker that is doing 600HP+ & revving to 10 grand (!!!) thanks to some meticulous internal balancing & trick ECU work, so with all my existing hardware (turbo, ecu, injectors etc) we are already well on the way to buidling a very streetable 400HP+ ride. With a new career that could potenially see me working away from home for weeks, maybe even a month or more at a time, I can not justify going really nuts on it when it would only be driven for a few days every month. I do miss driving it (its been about 6wks) however I do get to drive the wife's V during the weekends so at least I can still drive a Skyline! Look forward to seeing you on the cruise.
    • Update 2: Today I'm f**king pissed. Some of you probably saw my thread that I opened shortly after joining this forum, "urgently need expert/experienced opinion", in which I discussed the possibility of a porous RB26 engine block which I also found hard to believe. Currently both turbos are out since the shitty braided line that was installed by whoever fitted the GT28 turbos leaked oil onto the exhaust. Today while working on the cam covers to put new gaskets and half moons in, I cleaned the side of the engine block with brake cleaner. Some time later I saw that it was still glistening with oil or coolant so I dried that off. But it was wet again shortly after. Verdict: I'm royally screwed. What you can see here (hopefully, despite shit resolution), circled in red, is a crack above the turbo oil feed. Extent is a few cm long and basically goes from #3 cylinder wall to #4 cylinder wall. It slowly lets coolant through, even without any pressure behind it. I am absolutely dumbfounded as to how this crack even formed, especially since it isn't along the cylinder as it usually is but rather a horizontal crack. Probably a few cm in length. Not sure on how to deal with this issue right now. Most likely, the only true fix is a new engine block, and even a relatively well done temporary fix requires at least a full engine teardown. Neither of those really fit my timetable right now, the car has been in my buddy's garage long enough as it is. I'm open to suggestions, but I'll be looking into ordering a new 05U block soon so I have one ready for the coming year, or whenever the current block inevitably fails fully. (Most likely once the crack reaches one of the frost plugs) I think it'd be a waste of money and time to rebuild the engine with this block. Oh and I found a rust hole on the side pocket of the trunk, which someone covered up with sealant goop, a piece of number plate and bodywork filler. Fun times. So far for every issue we fix we just find a new one that is arguably worse.
    • I have not found this no. I put one back on a couple days ago with no drama. I agree they are tight, but no need to remove anything.
    • That is gates blue racing belt
    • Anyone found gates blue racing to be extremely tight/ almost impossible to install without moving the exhaust gear
    • Hello am apex am new here and also thanks for helping registering the forum
