Northern Sunny Coast Hinterland Cruise 19/06/11
Chris Rogers
 Share
  • Replies 43
run home was good. no traffic like usual on a sunday.
what did everyone think overall?
personally there were a few mistakes on my part. which I will correct on the next cruise.
the ending I got a bit out of whack as I was trying to raise the other two cars via two way and missed a turn.
the UHF radio that I had (thanks andrew!!!) were commercial items . range was great ontehm as I was talking to brad and andrew whilst they were still on the hill whilst john and I were already on the flats. I had not idea what band they were on but it was not the 460mhz band. for the 3 of us using them they worked well and kept car spacing fairly even. not sure what was happening on ch8 UHF.
the road to hunchy (razorback rd) was a blast when I did it in the van and a HELL of a lot better in a R32. the astra driver that was in front of us realised quite quickly that there were a lot of cars behind him and moved out of the way.
I had a blast and I know that John (isola) was having his share of fun as well. colin you are a mad man !!
thanks for the support from the SAU team and you guys!!! without you it would not have happened. keep watching as there is another in the works!!
I have a SW and border run already in the mix. border run has already been mapped all I have to do is set a weekend aside to finalise the run before opening it up to the public.
for the next one I will have a 5w hand held UHF and the commercial units.
keep the feedback coming!!
It was a good day and a great drive. Razorback was well fun (even though you were hunting for a brake pedal on the passenger floor, Chris ;) ).
Looking forward to another one!
And Kenny, you bitch... where was my hello?! Actually... what car was yours?
Maaate, I was sitting opposite Chris on the table, my car was the wine red R32 GTR, OZR32 number plates. Where were you mang?
I was in the lead car with Chris. Red 32 with tri spoke wheels.
And I was sitting at one end of the table. I was looking for a white stag!
Hey Chris,
Other than those minor things (which I didn't really notice) it was a really fun way to spend a day, and man were those lunches HUGE. I'll be attending again, maybe in the wedge next time. :)
I know a few people took pics / videos on the day, any chance of some links or something??
 Share
    • loved seeing the zenvo on the a1 just after the hatfield tunnel i was the guy in the white van trying to egg you on it sounded awesome and those exhausts glowing red inside insane cheers for the thumbs up tim and tom.
    • So.... when I'm finally getting around to having my power steering leak sorted, now it looks like I've got the same issue most A/T Skylines are having. My A/T light will randomly come on and I'm stuck in 3rd gear until I turn the car off and on again. Only 3 weeks ago I did a complete transmission service: Oil flush + new gasket + new filter. This came out of nowhere!! It wasn't like the car was driven hard. I drove about 3 mins down the road to get fuel and boom!!!  Anyway, I have a few questions and hope you fine people can help me out here. All questions are in red. 1. The solenoids: I was looking at the parts catalogue in Amayama and I could only find the Solenoids as an assembly. https://www.amayama.com/en/part/nissan/319404ax05 I read in another thread that Solenoid A = 31940-4AX02 & Solenoid B = 31940-4AX05 but the Amayama product has only the code of B. Is this the right part? Can anyone who has done the Solenoid changes or seen them confirm if this is the complete set of A & B?   2. Gasket and Filter: I'm not going to try change the solenoids myself because it seems difficult to do in a home garage with just 2 jack stands. I plan to take it to a shop and get it changed. I was also going to buy the transmission sump gasket at the same time so I don't reuse the same gasket. Should I just use the existing gasket as it has only been on the car since OCT 19th? (~3 weeks) Should I be buying a brand-new gasket and a filter? Does this job involve taking the filter out?   Thanks in advance to everyone. It's hard to find a video of someone doing a solenoid change on a R34 so any help you can give answering my remaining questions would make me less stressed.
    • Yea - From what I have seen from the video, the car idles like any R34 lol 50PSI of fuel pressure is hardly super abnormal, the regulator is working because the pressure remains static when the throttle gets revved, i.e pressure remains the same when manifold vaccuum changes. Bigger pumps on stock rails always bumped the pressure in the rail without using an aftermarket regulator to change that. Do you know what your IAC is actually doing? Has there been any data showing the stepper motor % etc? There's no way your idle is actually moving around the way the cluster(s) are indicating. You would hear the difference with the engine RPM flying to 3k and 1k in mere seconds. I'd be checking the wiring to the tacho. What the tacho is telling you and what the engine/ecu is telling you are different things. I assume your ECU doesn't display the spike. So whatever is telling the tacho to be at X rpm is doing something weird. When the going gets insane, you're on the wrong path. You've ruled out plenty of things that are working correctly/aren't the issue. Your idle isn't doing what the tacho is indicating. You have two seperate issues, I don't think they are linked, and the idle seems reasonably okay unless it's stalling which.. well, it hasn't. Troubleshoot the stall if it occurs by figuring out what your IAC is doing vs what it is being told to do.
    • So awesome! I love the RB with the exhaust on display.
    • NO HITS PRICE DROP   ENGINE - $8.5k ONO TRANSMISSION - $1.8k ONO
