ahh worked out who you are :) you finally got a place here - good!
actually be good to put a face to the voice since we did all of that via remote.
  • Replies 43
run home was good. no traffic like usual on a sunday.
what did everyone think overall?
personally there were a few mistakes on my part. which I will correct on the next cruise.
the ending I got a bit out of whack as I was trying to raise the other two cars via two way and missed a turn.
the UHF radio that I had (thanks andrew!!!) were commercial items . range was great ontehm as I was talking to brad and andrew whilst they were still on the hill whilst john and I were already on the flats. I had not idea what band they were on but it was not the 460mhz band. for the 3 of us using them they worked well and kept car spacing fairly even. not sure what was happening on ch8 UHF.
the road to hunchy (razorback rd) was a blast when I did it in the van and a HELL of a lot better in a R32. the astra driver that was in front of us realised quite quickly that there were a lot of cars behind him and moved out of the way.
I had a blast and I know that John (isola) was having his share of fun as well. colin you are a mad man !!
thanks for the support from the SAU team and you guys!!! without you it would not have happened. keep watching as there is another in the works!!
I have a SW and border run already in the mix. border run has already been mapped all I have to do is set a weekend aside to finalise the run before opening it up to the public.
for the next one I will have a 5w hand held UHF and the commercial units.
keep the feedback coming!!
It was a good day and a great drive. Razorback was well fun (even though you were hunting for a brake pedal on the passenger floor, Chris ;) ).
Looking forward to another one!
And Kenny, you bitch... where was my hello?! Actually... what car was yours?
Maaate, I was sitting opposite Chris on the table, my car was the wine red R32 GTR, OZR32 number plates. Where were you mang?
I was in the lead car with Chris. Red 32 with tri spoke wheels.
And I was sitting at one end of the table. I was looking for a white stag!
Hey Chris,
Other than those minor things (which I didn't really notice) it was a really fun way to spend a day, and man were those lunches HUGE. I'll be attending again, maybe in the wedge next time. :)
I know a few people took pics / videos on the day, any chance of some links or something??
there is a facebook page for it. search SAUQLD . if it wont let you add things - make request via the page and I'll sort it from there.
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
