R35 + Cobb Accessport + Godzilla Motorsport
I thought I'd give some real world data on the Cobb AccessPORT on an otherwise stock standard R35.
I installed the AccessPORT and reflashed the ECU with the delivered stage 1 ECU map, stage 1 TCM map and did a clutch re-learn. The effect was immediately noticeable. The gearbox lost some of its jerkiness from standstill. The launch RPM is now 3300rpm just like it says on the box. The first impressions from the seat of the pants is the engine now pulls much stronger.
I spent some time with Mark at Godzilla Motorsport on the dyno and the results were interesting.
With the stock tune the R35 made 391hp (~293kw) at all four wheels with boost starting at around 12psi and tapering off to just under 11psi.
With the delivered stage 1 map the R35 made 401hp (~300kw) at all four wheels with boost starting at just under 14psi and tapering off to around 12psi. That is a pretty modest gain, a lot less than the Cobb claimed 63hp peak gain, and doesn't explain the perceived performance gain.
The real gains were the 50hp+ increase across the middle of the rev range! 40hp gain (18% increase) at 3500rpm, 50hp gain (13% increase) at 4500rpm, tapering off the 10hp gains in the top end. More power where it counts most in a daily driven, part time circuit car. Definitely a worthwhile modification on any R35.
Keep in mind the Cobb AccessPORT is the only modification. Adding an exhaust and/or intake modifications will probably yield higher peak gains.
Godzilla Motorsport is now an authorised Cobb Tuning dealer meaning Mark has access to the full catalogue of Cobb parts. More importantly, Mark also has the AccessTUNER Pro software meaning he can go that step further than reselling/installing purchased tunes, and can do custom tuning work.
The next step is to do some custom tuning and see where the delivered Cobb maps can be optimised further and what gains can be had. I'll post there results when I have them.
    • Ahh got it. Well maybe install a drain for the catch can somewhere down low and accessible like a wheel well too....
    • Before you blow your car up, have you checked you've made all the correct modifications to the wiring if you're still using the RB20DE loom?   Some things to look at: The pin used for the map sensor on the RB25DET, is the same pin used on the RB20DE for the Ring Gear Crankshaft Position Sensor, no idea what you've got it plugged into now. The turbo pressure control valve solenoid you're talking about on the RB25DET, the same pin is used for the Variable Air Intake Control Valve on the RB20DE.   The factory manual has the wiring pinouts in it for you to check everything. It also has the diagnostics process to read codes out. In addition, there's a great table that shows what sensors and what actuators not functioning will relate to which signals. And Nissan confirm the as everyone else has from experience, the Solenoid being disconnected won't cause a fuel cut. However, the turbo pressure sensor being missing / wrong, WILL cause a fuel cut. https://www.nicoclub.com/service-manual?fsm=Skyline%2FR34-Workshop-Manual-English.pdf
    • I've been hunting info on the G Series II - this is best I have found so far(Link below). Still waiting on the G35-1150 comp map, kind of very keen   So how do we go about getting precision on that little table of yours ?   https://turbosbytm.com/sites/default/files/product/technical-info/Garrett-G-Series-II-Product_Flyer 25 30 35_1.pdf
    • yeah I get ~0.6L per session into the catch can. very ethanoly. It ends up overflowing out the breather of the catch can on circuit days too even with a 2.3L capacity catch can and I only drain out ~0.6L max. So every session I have to come in and drain the catch can, which is a hassle. So this is me cracking the shits and doing everything I can without removing the motor (back of head sump drain/breather and oil restrictors off the table). plans short term are: full length splash plates remove oem cam cover baffle add foam and reinstall at -10 or -12 AN fittings to the side of the cam covers down to the sump (luckily I already have fittings in the sump) Yes the ~340,000km unopened motor is probably not helping things
    • I'd use any fuel safe foam....mine went in 15 years and 15 rebuilds ago, still getting reused I'd have to say I don't understand swapping to studs to fit a particular baffle unless you are having a massive blowby issue, and even if you are addressing crankcase not head breathing is probably the next step.
