as description says ive got a set of greddy 272 degrees cams 9 1/2 mm lift and 550cc injectors - 7 turbos dumps etc ..can any one tell me are these cams to big for theses turbos?? and what kind of power should i get out of this combo in a rb26 or what would work??
https://www.sau.com.au/forums/topic/365272-272-cams-ported-head-7-turbos-rb26/
Consider they are the OEM item for a fairly well tuned OEM motor (R34 n1). Going to an enormous cam would be futile in a search for gains.
Consider again that they are well within the motors factory scope and a cost benefit analysis will begin to form.
Ultimately when wouldn't a ported head and the right cams be good? I say if your really serious about maxing out what you've got you should look harder at step 1 based cams and relax on the dreams of expensive port jobs. Be it myself I would run a set of gears as it seems the forum has proved they are a bang for buck performer.
step 1 cam size can be seen as 25x or milder 26x variants.. GL
Sell cams, buy cam gears and save the difference. Or if the cash is burning a hole in your pocket post details of your setup and we'll suggest something much more useful to spend it on.
well what i have got a the moment is the cams ported head 550cc injectors new r33 cranck stock rods, n1 piston 1mm o/s. cam gears n1 oil pump -7 turbos .arp bolts .. this engine was a stillway built engine but when i pulled it done every thing was stuffed and it was running a t88 turbo.. any ideas on what would be a good combo for these -7 turbos ...and would any one want to buy these greddy 272 degrees cams???
Dyno, I've also driven both cars on the street afterwards.
Both got to within 4rwkw of each other at 8000rpm (both around 305rwkw), the one with tomei cams is all over the OEM cam'd one until about 5500/6000rpm (from memory, may be slightly less, i dont have the dyno sheet here) where they are then dead even until redline.
very interesting.. finally someone with real results for poncam b on GTR, I've been on the fence as most say it's not worth the money vs result and stock works well
were they dialled in or left at zero?
    • Hi everyone! I’m the new owner of a 1996 R33 GTS-T, I’ve purchased this car over from Queensland and brought it to Western Australia and I’ve found that there is a hole cut out in the engine bay for the FMIC that enters into the wheel well (fender liners are in the boot). For anyone that has had to get their car over the PITS here, will this be a major issue?
    • Yeah I've spotted this one too, whenever it's lotto superdraw week and I'm browsing car sales dot com for my new ride They must be dreaming, maybe it's worth 150k for the link to Brock?
    • 100% accurate!  We are a pack of know it alls....  But, I bet people go to you when they have a problem! I've been on a bit of a clean up rampage too over the past month!  I've thrown more shit in the bin over the past 2 weeks than I have in the past 3 years combined! Anyway, it's all good fun being different! My wife sometimes does not agree!
    • ADHD in all form isn't about "can focus, or can't focus" or is hyper active or isn't etc.   It's all a dysregulation. Either time feels to be stationary, or time just vanishes in a split second. We are either under focussed on the task at hand (as we're over focussed on our surroundings) or we have no idea an atomic bomb went off beside us as we're so hyper focussed and locked in on things.   Not to mention the rapid fire thought process. What it takes a "normal" process to think up a solution to a problem, ADHD will be able to give you 5 different ways to solve the problem, and the pros and cons of each. While we can be highly impulsive and lack the ability to "control ourselves" we can also become paralysed with the inability to make a decision for ourselves. While most of us have an OCD like requirement for perfection, we lack the ability often to remain focussed to get things to a perfect state. Those with undiagnosed ADHD as adults, can often find the last part actually stops them ever attempting to do things that they have the ability to do, as the reasoning is often "if I can't do it perfectly, it's not worth doing"   As for projects... Ha ha ha, I still need to take the other half of my wall trim down in the Fiance's office so I can paint it. Need to finish digging and running the back yard drains, my R33, getting the Ninja bike registered (now being sold), the moped project, fixing either of the lawn mowers so they're reliable, along with a myriad of other things.   It's why I've been going through lately and just being brutal and clearing projects off that I won't actually ever complete. IE, moped will go to the tip, or be given away, bike is being sold, Subaru project being sold, some parts for other projects given away. Or I've been making myself focus on one thing at a time, by ticking off the smallest quickest ones first.   There's also a reason by our mid twenties we seem to be "know it alls", as we've all been down some of the weirdest and oddest rabbit holes when you follow the dopamine trail. It's often also why we're more a jack of all trades, but not a master of one.   However, pretty much all of my hobby projects, in one way or another, all come back around to automotive. That's my zen area.
    • Remember reading about this not too long ago. been for sale for a long time  this is like when the wife says you need to sell the car so you put it up for a ridiculous price no one will pay
