I currently have a r32 gts-4 manual, and want to put an rb26 into it. Ive searched through the forums and the topics were quite old, so would like to ask some advice on going about it. Is it worth doing these days or would it be better to just buy a r32 gtr? My situation would be, if i were to put an rb26 into it, i would go to a workshop.
https://www.sau.com.au/forums/topic/365273-engine-swap/
isn't that rb25de as is? Uses Rb20 injection etc???
Logic tells me turbo it and save big dollars, then slam stocky gtrs with it.
just confirm what motor u have and when i get to a pc I'll comment further...
https://www.sau.com.au/forums/topic/365273-engine-swap/#findComment-5828179
I'm doing the Stagea swap. All wheel drive rb25, I agree with giving thought to a r 32 GTR. There is a lot of satisfaction in doing a swap, rb26s are getting cheaper. If you did both a rebuild and a transplant it will add up quickly. If you buy a 32gtr you could also be sorting out a motor and wear and tear any way. Most people will tell you GTR. I still think a gts4 with swap is interesting. With you Vic address have you looked at legalities of the swap? If you're buying a GTR why not get a later model 33 or better still 34 and just service it, a 32 is often a rebuild/restore etc.
Edited by WHITE gtt
https://www.sau.com.au/forums/topic/365273-engine-swap/#findComment-5828217
Id honestly love to have a GTS4 over a GTR, there is a certain element of surprise that allures me.
Personally, having done the RB20 and 25 things in the past, Id probably try to pick up the shortest ratio diff I can and keep the RB20. Having a good turbo on it that will max out at something like 230rwkw would make for a very fun and respectable car.
If I had to have more, I would buy an RB25 donk and retune the exact above setup with non vct cams. That would unlock about 20kw more and all bolt back into place.
Doing an RB26 is probably going to set you back atleast 5k more than the above and will still be in stock trim... Only just faster than above if not at all.
https://www.sau.com.au/forums/topic/365273-engine-swap/#findComment-5829466
The GTS4 gives you the cheapest all wheel drive chassis, which you own already. This is an example of the type of Stagea set up you could buy. An upgrade turbo or highflow turbo, could see you performing better than a stock tired GTR. Potentially you could have the GTR performance envelope, and more money in the bank.
http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&item=370511948278&ssPageName=STRK:MEWAX:IT
https://www.sau.com.au/forums/topic/365273-engine-swap/#findComment-5829509
get a neo rb25 instead, better than half the thrashed rb26s out there
ultimately just sell the car and buy one with everything already done to it
He would have to track down a Stagea Neo all wheel drive RB25, agree better cylinder head and rods.
https://www.sau.com.au/forums/topic/365273-engine-swap/#findComment-5829858
I think the main point from the OP is that he'd be paying a workshop to do it.
Honestly, you may as well hand over your wallet, bend over and drop your daks.
I really can't see how you are going to come out ahead - $$-wise, kw-wise - getting a workshop to do the conversion. They charge for every hour they spend.
Even if you were doing it yourself in your shed it would be questionable. At least then the risk would be your time rather than $$.
If you are dead set on getting a GTS-4 conversion, wait for one already done to pop up, it's bound to happen.
https://www.sau.com.au/forums/topic/365273-engine-swap/#findComment-5830042
If he buys an r32 gtr, a move which makes sense to me, when the engine has a problem, (quite often clutch electricals, ATESSA, suspension as well), where will he go? A workshop as many on this forum do. He could remove the existing engine and donor engine, with friends and an engine crane source parts, to control his costs.
https://www.sau.com.au/forums/topic/365273-engine-swap/#findComment-5830210
Do whatever makes you happy, whatever you want more. Nothing is cheap, yet I would be damned if I could not beat a GTR with a GTS-4 dollar for dollar. Performance and reliability as said above.
GL
https://www.sau.com.au/forums/topic/365273-engine-swap/#findComment-5832626
If you picked a sensible power figure above a stock GTR, I'm sure I would get there more cheaply starting with a gts4, than buying a gtr and upgrading it. Similar to the post above.You already have a GTR chassis with an unflared body. Consider the nz gts4 below.
Edited by WHITE gtt
https://www.sau.com.au/forums/topic/365273-engine-swap/#findComment-5832703
    • Hi all. Been a while but things are moving along. I just have something that I am wondering about. Since I will use OEM turbo oil pumbing, I got myself a new bolt, the one that goes into the engine block oil feed. As I recall (and see visually) this bolt comes restricted with I think a 1.7mm hole? Not quite sure but it was something around that size. The turbos have 1mm restrictor bolts installed, as necessary due to ball bearings and my higher oil pressures. Can I now just use that OEM bolt with the 1.7mm hole in for the engine block or will this actually be too much oil flow restriction and I have to drill it out first? In my head it would make sense for the bolt to be at least 2mm wide as both turbos take "1mm of oil flow". Do let me know if my logic is flawed here, I just want to make sure I don't kill my turbo bearings with too little oil. Don't know if I can trust the saying I read somewhere that ball bearing turbos essentially only need an oil mist
    • There are several aftermarket options available, from not-too-painful moneyhttps://justjap.com/collections/driveshafts-bearings/products/d-max-reinforced-replacement-rear-driveshaft-set-fits-nissan-s13-s14-s15-r32-r33-r34-c35 and  https://justjap.com/products/crank-motorsport-billet-rear-axles-fits-nissan-skyline-r33-gts-t-r34-gt-t?srsltid=AfmBOorQk4xkGUa98kO7v2ePLUiNt-HRrM2AwWNw9mbSIVE1ujBVwY__, all the way up to The Driveshaft Shop https://driveshaftshop.com/skyline-cv-axles/
    • Yeah based on old XRC5964S specs, it looks to be roughly GTX3576R sized? But this 5964S compressor will flow 90lb airflow somewhat similar to the compressors in both the GTX3584RS or G35-1050.. I fully expected the 0.64 rear A/R to choke up top - seems way too small from typical convention - but these are seemingly beneficial over the prior 0.82 results.. Be interesting to see if he comments on the EFR question in that thread - he mentioned in a prior video that BW EFR's were the "cats pajamas 10 years ago", but by the sounds of things all his kits have been using Xona for quite a while now.
    • Yeah it’s still got the oem manual gearbox and clutch, only kinda mods are a blow off valve, coil overs, and a aftermarket intercooler. Also had it for about 2 months now with a lovely midnight purple paint on it.
    • Yeeeppp, been following a lot of the testing on the latest Xona stuff and there are some mental results.  He also went over 1000hp @ 4 hubs on his Mainline with a XRE6364S (63mm) which was also well into the 20psi range before 4000rpm on a 2.5. Crazy stuff. Fwiw the XRE5964S is basically the modern equivalent of their old HTA3582 - would drive nicely enough on an RB25 or 26, but proven capable of a huge amount of power if you want to spicy with rpm tho even at sane boost levels will make stout numbers
