All cats are going to cause a restriction, it's just how much. OK, so I am the only one with some data. I'm giving it a go. My cat has been on for 80,000km and is ceramic so I might as well replace it now.
Another bonus is it will make the exhaust sound a bit deeper and louder, and mine is fairly quiet now.
Hopefully I can get a bolt-on from Sureflo.
I swapped my stock cat for a hiflow LOBOKKA (ebay) metal cat with 100cpsi, difference was barely noticeable except in mid-top but even so its bugger all.. Already had a full 3" system from turbo (but dump is stock :( ), 12psi boost, FMIC, Nistune ecu, Walbro fuel pump etc.. The cat made stuff all difference in my ride, maybe my exhaust system wasnt bad to begin with..
stock dump and stock turbo?, I wouldn't expect you'd notice too much with a 3 or 4% increase anyway. It's worth about 1psi in power if you are running 1bar.
Edited by simpletool
http://www.nengun.co...super-catalyzer
Beast of a cat. Running 300awkw, no end in sight. Bit costly but you get what you pay for.
I usually say that too but f**k is it lined with gold or something? That's a bit excessive for a cat!
Agreed.
Ron P further up the Mtns had a METALCat on his R34 GT-R and destroyed it within 15 months thru running rich > no warranty
Its definitely very illegal to have it straight through- does anyone know the penalty involved? Rumor is its a pretty damn nasty fine.
My cat is just an xforce 3' high flow job, heard they arent the best but my 33gtst is pretty stock- aiming for 200rwkw so it should cover that.
lol good thing about being in tassy. ive had my car registered for 2 years with an open 3.5 " side pipe from turbo.
been pulled over by the cops plently of times. they dont know what a cat convertor is/does so they dont look for it.
my exhaust exits after the last door so they dont care its a side pipe.
they fail to realise its on the passenger side ( illegal as it points towards footpath)
they have no tools or ways to measure dB levels.
they usually tell me to go home and put a number plate on it or to just take it home its too loud.
the orange wheels and stickers are a pretty good give away it should be at the track. but on the other hand i dont drive it in the cbd because i know the noise would just be unnessarcery. i dont hoon about in it. and im polite and helpful to police and explain im on the way to a worshop or to load car onto trailer... we have it pretty good down here as long as your not a tool
sorry about the rant lol... and if Mr tassy policemans aare reading this... :thanks::cheers:
sell the unused cat you have, find a 3 inch inlet/outlet used or f**ked cat.... bash the guts of it out and run it like that.
if the cops where you live are not likely to even look for a cat then put a decat pipe in perhaps
Haha, thats a killer set up to run on the street, That sort of set up would land you a defect very quick smart where i live (sux for me!)
I second what you said about the cops though, i have only had good experiences with them. If you dont act like a smart ass and be as honest as necessary they seem to treat you with respect- I know over the years they have let me off for tons of things that i should have been fined/lost license for.
Agreed.
Interesting, I didn't know you could poison a cat from simply running a rich mixture. Keep in mind any decent cat manufacturer will know their cats will be used in a rich environment.
I thought cats were killed from phosphorous, lead, manganese, silicone, etc. You'll only introduce these things into the exhaust stream if your engine isn't healthy or are using certain additives or leaded fuel. I don't know about E85 though.
200cell is the most high flowing "legal" cat you can really go.
if you want to start going illegal go 100cell.
but in all honesty, most people wont make enough power for a 200cell cat to ever become a restriction!
Almost - Platinum and other rare materials. The value of platinum is so high that there are stories of people stealing cats from cars overnight etc, for the rare metals inside to sell. So almost lined with gold yeah. :D
think my cat has been 'poisoned', cars been running rich for a while and constantly does small backfires when changing gears and slowing down under engine braking and and is not as responsive as it should be :unsure: , gunna put one of those ceramic catco cats in as not running or ever going to run big power.
    • Pretty much what you'd expect at that power level. Hypergear turbo, long list of supporting mods, full Haltech catalogue, etc.  I'd say this goes for most drivers, suspension is still a dark art for most people. And it's really hard to convince someone how much better their setup could be...
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
