Haven't posted here for a few weeks I sold my R32 gtst to another member (hope he's enjoying it)
So I bought a 98 s14a resprayed with only an exhaust boost controller aftermarket manifold and s15 turbo and side mount intercooler and coilovers
Dyno'd it on Saturday at boostech in fivedock it's doing 175rwkws at 10psi but its running very close to lean so I need to upgrade the injectors and grab a power fc so it can be tuned properly
I searched around the Nissansilvia forum but to be honest ( no offense to anyone whos on there) it's pretty boring
So is there much love here for the 200sx or am I gonna get bagged everytine I mention it?
https://www.sau.com.au/forums/topic/365308-ive-gone-over-to-the-dark-side/
Really I was just reading a thread about the difference between the 2 my mechanic has always tuned his cars and customer cars with the PFC so he was the one who told me to grab one I'm currently looking for one around the 700-800 mark
the difference between the 2 is minimal, but the nistune retains all the advantages of the stock ecu, such as using the knock sensors properly, rather than simply to give a readout, and more comprehensive cold start tunes, and the ability to view fault codes (not sure if the pfc can do this), etc. power wise they should both be the same. main advantage of the pfc is the hand controller, but from a data viewing point of view, you can get an ecutalk unit that will show a lot of data. it runs off the consult port.
Yeah go Nistune with the stock ECU you have. Your tuner shouldn't have a problem using it at all but best to find one who uses it regularly.
S14a huh, make sure you get some pineapples and strut bars. Those things are loose as a goose when stock. A turbo like the 2860 or 2871 is also a good idea if you can get one cheap.
Edited by simpletool
SR20's are easy to tune.
My brother used to have a 99' ADM S14a with the S15 front (pic at the bottom). He was running a Jap spec S15 ball-bearing turbo, Nismo 550cc injectors, Apexi avcr, fmic, pod, turbo-back exhaust, PFC, custom diff (4.44 im sure) (prob a few other things im missing) and it was making about 330rwhp on a safe tune. Don't need to spend much to get them into the mid-low 12sec range.
Nistune is good, as it refines you stock ECU.
PFC, I think would allow you to be more in depth as in if you are savvy enough to tune it yourself with the hand controller.
+ It gives you the ability to cycle through the ECU and see it for yourself.
I would consider a front mount intercooler if I had a S14A, but that's just me.
Hah! Yeah I am on NS, it's quite funny actually.
The PFC allows access for many more parameters to fine tune I always thought. From my experience the stock s15 turbo is good for around 185-190rwkw depending on dyno (with injectors, fuel pump, FMIC and ecu tune). For an extra 15rwkw I don't think its worth it. Get a larger turbo (then your in 220rwk+ range and worth it then. ps try melbs15 forums. There is a lot of activity there and they seem to be a friendly bunch. You will also find many people selling cheap parts eg PFC, boost controllers etc. Good luck and enjoy the car.
Still, he would have to get upgraded injectors, fuel pump, FMIC and ecu tune, yeah..?
Or how much can the stock parts handle until upgrade is needed?
I already need to upgrade the injectors to atleast JDM s15 items as the s14 ones were maxing out on the dyno
Plus an FMIC is next on the list
My only problem with the nistune is installing it I looked on the site last night
I have a first level degree in electrotechnolgy and I used to solder my on guitar cables and pickups, but I'm a bit scared to stuff around soldering things onto my ECU
Edited by stig mick
Nice s14, after I'm done with the power I would love to do an S15 front conversion but the head lights are so expesive, if I'd bought a series 1 I would defiantly do it but the s14a has a decent looking front as it is
All good then and yes, a FMIC will do you good.
Yeah, I'd leave the ECU to the mechanic...
In the mean time, solder some humbuckers on your guitar and get some mad 'Chug Chug' and Shred going in the Heavy Metal Music Thread \m/
:D
:D
Lol nah no more guitar cars put a stop to my playing days been in heaps of bands one of them was playing a club gig every weekend fir a year but I haven't picked up a guitar in 3 years
I'm pretty happy with the power I'm getting from the 200sx ATM it's faster than my r32 was
Would a fpr be a good idea for the mean time to bring the air/fuel ratio back down to acceptable levels without needing a new ecu?
the best bet would be to see what the actual cause of the car leaning out is. it would be worth getting yourself a consult cable to check the injector percentages. it may well be that it is the fuel pump the issue and not the injectors (although i wouldn't be suprised if it was injectors). or in the short term you could try getting the injectors professionally cleaned. most likely they will be at least a little bit blocked, so you should see at least a small gain in the amount of fuel they can deliver.
as for the PFC being able to adjust more parameters, well yes and no. the nistune has a much more indepth mapping system (even if they have less map resolution). all up the nistune has something like 10 or 15 different maps which all interact with each other to a certain extent. the pfc has 2. 1 for ignition, 1 for fuel.
Ok cheers I'll get my mechanic to check that out
While he had it on the dyno he got it up to 170rwkw with the mods I have listed and the afr was reading 13.4 as soon as he saw this each time he back off the throttle
for 10psi boost the injectors if working properly should not be maxed correct?
well at 10psi they shouldn't but at around 170kw they would be getting up there a bit. my mate was running 15psi on his s13 (with the t25 turbo) and it was fine, and his missus had a s15 turbo on her 180sx. it was running 15psi with no fuel issues. my old 180sx was running 15psi on the stock turbo making around 170kw and it wasn't maxing out the injectors, however the first time it was put on the dyno it was leaning out and only made 135kw (before they backed off). a new fuel pump solved the problem.
So I could have fuel pump issue or possible blocked injectors?
I might have to get him to check that before I spend over 2000 bucks on upgrading the injectors and ecu as I don't have that money lying around and I'm quite happy with 170rwkw for the time being
I love silvias but if i had one again, first thing id do is put some rocker stoppers in (cheap mod to prevent your rocker arms cracking off)....yes this happened to me; put my foot down once one night and pop (took the camshafts with them too)
    • I believe Unimog is the only vehicle that has it (from the manufacturer). I haven't seen aftermarket permanently connected kits, but I haven't looked either.
    • Ha ha ha, can't overthink when exhausted... Oh how I wish I had that power! I can be absolutely dead set shot, and my brain will still go "we need a good 3 or 4 hours to just think about everything and anything before you may sleep... My biggest thing is making sure I give myself enough sleep. I don't operate on even 7 hours of sleep! I attempt to give my body 9.5hours sleep a night to be able to function. I don't sleep the whole 9.5, but I need to make sure I offer a big window. I also take a single supplement, which is to help with long term health, and fighting inflammation, and I notice it helps massively. Especially me sleeping, and just less "achey" in the body. Have also kicked sugar, and gluten. A majority of people with ADHD don't go well with gluten. It causes a really interesting natural opioid overdose in the brain, which causes bodily issues and sensory issues.
    • Yeah that's what I meant, permanently connected not manual
    • Yep. But typically that's just run a hose down to the tyre while stationary.   Oh and the Unimog will automatically air up and air down tyres from the onboard computer for you too.
    • There was a good video somewhere, maybe Kurzgesagt that linked physical activity to ADHD/Anxiety/Insomnia etc. Basically the body WILL spend energy doing something if you don't spend it doing anything physical. It isn't fun, but I personally have noticed I've never been overthinky, or unable to sleep if I'm physically exhausted from doing a lot. The musings around it seem to indicate that this is one of the reasons/mechanism that physical activity improves mental health/wellbeing etc, by more or less not using that 'extra' energy to overthink, be anxious, inflammation, etc. There's also the fact that every obnoxious exerciser ever says it's great and helps which is extremely annoying. Like people who say the same thing about travel being the best thing ever. I mean, they clearly are, but blah. I started doing a LITTLE myself (think 3x15min per week) and honestly did notice the benefits, aiming at life quality when older. Which is sooner than you think. Getting something into your routine that you can actually make a routine has helped me at least. This post brought to you by procrastination between sets.
