  • Replies 108
heh, teh saab won't drift, no matter how hard u try (as akira and oz can testify) - but thats Ric Damelian's problem now :(
good to see some old faces here, even if they're just visiting - so get ur arses up to the show n shine...its your chance to 0wn teh gibson gtr :)
good to see some old faces here, even if they're just visiting - so get ur arses up to the show n shine...its your chance to 0wn teh gibson gtr ;)
OWN?!?!?!?!? :jump:
you can win that car?
:P more 0wn like the pics that tactic posted....nice try tho!  you dropping by?
heehee damn! no harm in trying!!!- Ill be coming up man, I dont know whether im coming up with Marsss and the guys early or if Im going later?? probably later
I might hand in my papers and stuff to become a member too
what time are you guys heading up there and where are you meeting up??
    • How to wreak havoc at a bogans party... Swap out the goon bag hanging from the clothes line with oil bag... Watch chaos ensue during Goon of Fortune....
    • Hey everyone,   I’m looking for some advice on replacing the timing belt on my RB25DET Neo-powered 1998 Skyline. The engine was fully built about five years ago, including a fresh timing belt, water pump, and other essentials. However, since then, the car has only covered around 2,000–3,000 miles. It’s currently making around 650hp.   Even though the mileage is low, I know timing belts have a time-based lifespan too, and most recommendations suggest changing them every five to six years or 50,000 miles. Since I’m at that time mark, I’d rather not take any risks and plan to swap it out soon.   A few things I’d like to hear opinions on: 1. What’s the best belt for this setup? Should I go with an OEM Nissan belt, or is the HKS fine-tune a better choice given the power level? 2. Would you bother replacing the idler pulley and tensioner at the same time, or only if they show wear? 3. When swapping the belt, is it necessary to lock the cam and crank gears in place, or is lining up the timing marks enough? I’ve seen different approaches, and I want to make sure I do it right.   The water pump was changed with the rebuild and isn’t run off the timing belt, so I don’t see a need to replace it again. I just want to make sure I approach this the right way.   Any insight would be much appreciated. Thanks!
    • How does this compare to the internally gated g25-550 in terms of power production at same psi and spool
    • Did you find that your voltage of the battery wasn't where it's normally supposed to be? for example on my r34, it's at 14.5v when running after a few seconds, but I noticed when I had a rough start and it initially wasn't idling correctly, the voltage on my triple gauge cluster was showing lower than usual. Seems like the alternator is starting to crap itself
