Just finalised and paid for my new turbo.
Now the waiting game begins. Should arrive on my doorstep in somewhere between 6 and 8 weeks time.
With paypals shitful exchange rate it ended up being just over $1700 delivered... Being different is expensive. Plus side, that's still about $600 cheaper than *any* local distributor could do for me.
  • Replies 3.6k
Posted Images
soooooo today ends a week and a bit of fitting parts and getting the car tuned. Ran into plenty of issues along the way (injectors missing o-rings, z32 wiring was backwards, fuel lines backwards).
so after a long week some people to thank.
AM Performance; Custom dump pipe and intake. sounds sexual and clearly makes the power
Willall; If you have a modified car, specifically if it has a RB there is no other place i would take my car. They help troubleshoot the issues along the way and were a massive wealth of knowledge. The car drives fantastically, AFR's are beautifully done, makes great power (alot more than we were expecting). If you have a skyline, make sure you pay them a visit. world class workshop right on your doorstep, dont beleive me go and have a look. Chat to Martin and Gareth and im sure youll agree. Prices are more than reasonable too, youll be over the moon as i am.
Willall + AM Performance :worship:
Thankfully it's all over with now eh? I'm still laughing about your traction "issues" in all gears "laugh"
270rwkw steve :thumbsup:
Thats precisely what I'm running, could you either pm me ur setup or list it here? I'm keen to know what other gear people are running
Is there much overhead for more power or are u aiming for response? I am... tho it seems the N1's don't breathe as well as 2860-5's so I think thats what I'll put there once I do the bottom end (2 yrs time)
-D
Sure you do.
With my new turbo I'm expecting response similar to a JDM S14 turbo and power getting pretty close to what Josh is currently making.
i dunno eh, these buggers spool from 3k and im getting 275kw/420nm torque at the wheels.... some fine tuning to the boost controller remains as well as cam gears but eh, its more than enough for a non-rambo daily driver like me
I'd like to compare his powercurve to mine. Single vs double with only 100cc engine capacity difference. Would be interesting...
-D
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
