Ben, who is feeding you this rubbish............try running -5's (with or without stock boost) and see how they run without a tune....they def have different trim and comp size hence your AFR's will be all over the shop
You're requirement for a tune is based on AFR"S (in this case) not just boost.........I'm not even referring to boost
Cam gear adjusting will affect your valve timing.............a good tune will give you a nice balance between correct AFR's and ignition timing
well this is what ive gathered from the nistune forums and a few other sources
I'd be the first to admit I dont know what Im talking about, which is why imma spend the next 18 months figuring out what I want to do when the time comes - I want to do the brakes/rims/rubbers/suspension and interior over the next year and a bit - performance is not a concern atm
that said, when it does become a priority, it would be good to know wtf is and wtf isnt.
simply telling me that ive been fed rubbish isnt helpful tho.
-D
  • Replies 3.6k
Posted Images
That's fine, and that's why I said, based on your sentiments towards your current setup, you'd be happier IMO with a -5 setup which is pretty much the next step up from where you are now.
Spending $$ on -7's will not see much (maybe a smidge) difference to your current setup.................R34 N1's are a different story again though (they sit somewhere in between your current setup and the -5's if my memory serves me correctly)
Hope that helps a little............good night all :D
further truth would be even to say that perhaps the next upgrade just would not be worth it for its purpose.
how often does a daily need 300kw in any case?
-D
-7s are the same as 34 n1s
33 n1s are laggy pos
If you're happy with 300kw then you want -9s as they are basically an updated -7, they make more power but have extremely similar spool times. They are however slightly more expensive. -5s need something to help wake them up. Lots of boost is ideal but obviously not for a standard motor. I use poncams. E85 would help massively too. -5s+E85 would be the perfect street setup on a gtr IMO.
-7s or -9s are the turbos you want.
Just go dash 5s... In my opinion they are the perfect compromise between power and response. My 26 with poncams and 18psi makes a nice 320awkw with nice response and fantastic power delivery. Sure the turbos have a lot more left in them but when i build my motor then ill push for more. Until then Im more than happy with my setup
Congratulations to the f**king retard silver skyline owner who was involved in the hit and run death of a motorcyclist this morning. You have held up 100% of the traffic from anywhere in Adelaide to Wingfield.
yeah its pretty bad, i dont understand how its possible to not even realise you hit someone. the news was quick to mention that police are searching for a silver nissan skyline
http://www.adelaidenow.com.au/news/south-australia/serious-crash-halts-salisbury-hwy/story-e6frea83-1226063866676
"silver or maroon nissan skyline" what? they arent similar colours haha
Dohmar, if you're wondering what turbo's to get then you should listen to people with them and they probably would all tell you that any boost level under 18psi is probably not worth your while. its a too laggy setup for between 250-280rwkw. they start coming alive with 18psi. because then when they spool up they go hard!!
i had my 2860's for ages, started on a stock motor and they were crap, laggy as full boost by 5000rpm and only made 210rwkw on 14psi. this was with all stock ecu fuel pump and injectors.
with a rebuild motor the comp was much better cos it wasnt so tired. it managed 250rwkw with still std ecu and 14psi
it wasnt until i got my nistune and injectors and fuel pump that i could push 18psi into it and thats when they came alive. i ran 320rwkw on boostworx dyno.
IMO they're a good turbo for the compromise between a mid 300kw car that you still want to use on the street.
so if you want response and are not looking to be in the 300 club then don't buy them, stick with your N1's or go for -7's or -9's
Okay the ARC intercooler didnt make any difference!
Damn!!
it probably cools better but obviously wasnt the thing causing the flow restriction.
the only things left could be the STD cams or the 3in exhaust.
i'd love the car to have a lumpier idle, but i think with possibly being a home owner in 4 weeks time is going to put a serious halt on getting cams.
looks like i'll have to be satisfied with 365rwkw for a while.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
    • A thing I wasn’t happy with with enthusiast was during the initial phone call they told me they’d insure it for 130k but needed photos.   I then sent them photos and they told me $80k as there were other cars either similar modifications available for around that price, I told them to send me the links to said cars so that I can buy them. i then sent the modification list with prices of the parts (no labor) and the price then came to 115k, which is still shy of the 130 that was agreed in the initial phone call
    • Ask me a bit later this week before payday
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
    • Oh man what a deal.... Funny enough (well not really) I sold a car to some old dude (buying for his Daughter) on a Saturday, He asked if she could take the car now and pay me the money on Monday as the bank wasn't open. Needless to say I told them to come back with the cash or get f**ked! Luckily the money seemed to magically appear in his pocket a few minutes later, so it all ended well (for me).
