The Wasteland 2011 Edition
Nightcrawler
 Share
  • Replies 3.6k
Posted Images
sled nice taxi ull be amazed how agressive the little turbo on the xr series pulls they max out at 320ish but thats the most impressive rollons ever with a zf u did get a zf didnt u ? or u go stick :rolleyes:
one of the blokes had a ego one 320 on tolly did a 12.2 @119mph but on the street got car lenghts on any of us at 60km/h on wards weapon 4 sure :thumbsup:
On the dyno with stock ECU I'm assuming? I've never checked to be honest...
Needs a tune pretty bad, getting an absolutely horrible amount of k's out of it.
There's no tuning that you can do with a stock ECU. The only thing that you can do it adjust the base timing at the CAS and anyone can do that with a timing light. If your fuel mileage has become worse then i would be looking at your O2 sensor.
Sorry bud, here you go:
Specs to follow via a Dyno Sheet next week when it goes to Willalls so Martin can work his magic
Really looking forward to this SLED. There are a lot of new techniques in the tuning of these cars that arent being implemented in South Australia currently. I know this as none of the SA Tuners attend the Australia wide advanced Ford tuning workshops....and I am the headmaster :)
Your tune will have 'all the fruit'
Also prob won't hurt if you changed the plugs and done a service at the same time, ie oil, coolant, filters, give your intake filters a good clean. That should get your car running just right :D
 Share
    • as above find out what you want to do with it but extremely general Id get a more modern car with tech in it - add suspension, brakes and tyres - drive it if needs cooling add that - drive it  maintain and have fun
    • You'll need a 25 head. It's no bueno doing it with the 20 head. The bore diameter is....different. Very different. Hasn't been done in the wold since the larger bore twin cam heads became an option (ie, not since the early 90s!)
    • I’ve gone down the Rb30 rabbit hole the past few days and it sounds pretty sweet, only thing that really turns me off is the $2500 price tag for a bare block people are asking around here. That being said I’ve got a snowmobile I could sell to get the majority of the bottom end done lol
    • Compression test is good. Leak down is same across the board but could be lower. It's a loose engine, I specifically asked my builder to build it on the loose side as I was planning on running 35+psi. I'm also growing more convinced it's blowby. My engine builder wanted me to do the good old oil in cylinder then compression test to see if it goes up so I'll go ahead and do a cold, hot and hot with oil compression test to see.  I also went ahead and filled my catch can with stainless steel wool to see if it accumulates anything now. I'll report back in 200-300km's.
    • I see now that it is liquid. Highly recommended. I have 25Neo in mine. It is nice to have some torque, any torque at all. Something that the RB20 is just completely bereft of. Mine will** pull away from 800rpm in 5th. Same rolling start is best done in 2nd with a 20! **Will, and does regularly. Might even be able to do it from 600 rpm, but that's not really all that feasible in traffic where it would take a bit too long, and is the only place where I roll around that gently. RB30 even better! (Perhaps just not under a 32 bonnet).
