  • Replies 3.6k
Posted Images
I know its a long shot but does anyone have a long drill bit/drill bit extension so I can drill down from my ceiling down the wall cavity through the timber studs so I can feed some wires through without having to cut the shit out of my walls. Would need to be about 1 to 1.2m long
trade tools direct have 2metre long ajustable drill bits for like $199 i reckn they were but if u do whative done just get a spade bit and a piece of threaded rod and weld it on the end and then shape the end for the drill bit all bits at bunnos for less than $50
if u really need i can hook u up with mine :thumbsup:
Working at a house (being reno'd). Got talking about cars to the tradies. Tradies say dude who owns this house just sold a couple year old gun metal grey GTR and got a newer one and the brakes are huge.
I ask if the plates are GUN 350 and they're like "How the hell do you know"...small world.
So you're doing some stuff at Walkerville .... I haven't been down there to check it out for a few weeks, but last I heard from John it is coming along very nicely. And would you mean this new R35 (with my wife and child in it)? :)
But have you seen the new Land Rover? :D :D :D Porn, I reckon!
I was going to buy my own but for a use once application I couldn't justify it. I was gonna go down the built my own route if no one had anything available but looks like I'm in the clear now!
And Steve, just doing a bit of cable management and running another powerpoint behind the TV
BLUEEEEEEEEEEEEEEEEEEEEEEE :worship:
hmmm there's an unsual sight [sKY350] on jacks :nyaanyaa:
which land rover, the new Disco or the new soft 4wd?
Give me a ring I have a few spade drills with extensions for going down the wall
Yeah did some gutter guard around the back verandah, where the verandah meets the house itself. Tell John if he wants the whole house done (which he should as they are chockers with leaves), get in contact with me. Looks like a damn nice house. How far off have they said from occupancy?
Didnt see any of the cars. Just one of the guys said enough for me to figure out who it was. He was memerized by the "big brakes"
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
