  • Replies 3.6k
Posted Images
Its only a conservative little 13psi tune through the stock exhaust on 98 pump. Just a nice 'area under the curve thing'. Sled has the dyno graph :)
Just a little tizzy and tidy up then. Probably still more than enough
Torque figures are my area of interest. Driving my old mans 03 ba xr6t again on the weekend was fun. I forgot what it was like! Like wrestling an croc compared when compared to the easeof my 32
hey sled went to willall today for the commodores owners club dyno day mainline is hungry hungry but still delivered on the torque figure which i spose is good did 340 kw but 1087nm torque's had a good old chuckle with dingo and looks like i might in the near future have a looksee at all this zf tuning jargin hes banging on about more than likely ur car will be the first or one of the first to have it done to cant wait to see whats the g..o :thumbsup:
did i mention i dont like mainline hahahah thats the weirdest shit tho
the bloke who took out the day bosko(ba f6) reeled off 510rwkw on a d/d then 447rwkw today with a very same torque figure 1088nm i think it was but that would definitely be doing high nm @wheels running 24+psi through a 4litre
Hey Jet, I did expect you to drop below 400 but not a whole 80kw >_<..........that may explain your ET cause 421 should see a 10 ET.
Seems Bosko dropped a similar amount.........I'm guessing you guys had the original power figures taken off Heinrich's dyno, yeah??
Makes me think that if I can get get anywhere near 300kw on Willall's dyno, with a smaller turbo, stock cooler & exh from Cat-back, that'll be lethal enough for a daily :yes:
Mine will be on pump gas.........I'm guessing you guys were running E85 again on Willalls?
yeh original were off heinrichs 510-421 and yeh both running e85 as u said if u can reel off a 300 on a mainline its guna cut the mustard nicely. we have done some back to back runs across adelaide hpt vs k.p.m vs southern hi tek but they were all d/d and were showing very ball park figures but the mainline seems to be the differ
we all know the dyno debate but it just seems to be mainline is the most accurate might we say :worship:
Sorry guys, just got home.
Martin I didn't get the print out.......I think you ran out of paper and went looking for some. Can you email me a pdf of it please ([email protected])
Now, as per above past posts, I'm very happy with the tune and considering I'm running a smaller turbo than an F6 and pump fuel, 307kw is pretty much what I was hoping to get.
The beauty about this is that it's still like a stock car to drive around as a daily and not only looks like one under the hood but sounds like a stocker as well.
Even after 60kph, you definitely only want to feed the power in slowly other wise I'm going to have to invest in a Tyre Power franchise........absolutely love the down low grunt.
I'm betting that with another 2 or so (conservative) psi and E85, it'll probably see over 350kw........not bad for a daily Taxi that's very quiet and comfortable.
I'm very happy with the Willall tune and have learnt the hard way now as far as past tunes go; "The poor man always pays twice".....I'll never go anywhere else again.
Thanks again Martin........and for lunch :cheers:
Good numbers for only 13psi Pete. :thumbsup:
Sled the printout is sitting in the printer still, but will email you PDF this morning.
BTW nothing beats the Tai Ito Lemongrass chicken Banh Mi roll!
    • Is there a diameter difference in the stock to Nismo? If so, the weight alone won't be indicative when comparing flywheels of the same diameter, since the radius of the flywheel acts on the moment of inertia with a square factor, where as mass is linear. Roughly going from a 4.5kg flywheel with radius 20cm, to a 9kg flywheel with radius 14cm would see them act the same. This calc is just here to act as a brief numbers comparison and reflects no actual RB flywheel diameters etc. it also assumes even weight distribution (thickness) throughout.
    • It seems this could be due to a restructure/team direction change... Or... You're working with a different category of vehicle... Or you've decided you'd rather be able to play with your own cars again...   I'm hoping the latter...
    • had 4 weeks off over xmas and well did some stuff to the shed and BRZ, well short of is I don't work full time in supercars anymore as of yesterday.........
    • Did you get any down time over Christmas, or have you had any since to play with this? Or have you given up and are trying to get yourself a second hand V8SC instead?
    • A random thought I had just before I hit "Submit on this post". If brake fluid, in a container in my garage that has never been opened goes bad after 18 months, why can I leave it in my car for 24 months in an "unsealed container"... Secondly, some other digging, and brake fluid manufacturers seem to be saying 5 year shelf life... Me thinks there line on 18 months for an unsealed bottle is pretty much horse shit marketing spin. Kind of like how if you drive a car and don't run a turbo timer your turbo and motor will die horribly...   Where I started on this though... Someone (me) started down a bit of a rabbit hole, I don't quite have the proper equipment to do Equilibrium Reflux boiling per the proper test standards. I did a little digging on YouTube, and this was the first video I found on someone attempting to "just boil it". This video isn't overly scientific, as we don't have a known reference for his test either. Inaccuracy in his equipment could have him reaching the 460 to 470f boiling point range in reality. In the video, using a laser temp gun, he claims his Dot3 that's been open in his florida garage for over a year gets to about 420 to 430 fahrenheit (215 to 221c) Doing some googling, I located an MSDS for that specific oil, and from new, it claims a dry boiling point of 460 to 470f. Unfortunately they don't list a wet boiling point for us to see how far it degraded toward its "wet" point. While watching it I was thinking "I wonder what the flash point is..." turns out its only 480f for that specific brake fluid....   As for testing the oil's resistance, I might not be able to accurately do that unfortunately. Resistance level will be quite a LOT higher than my system can read I suspect based on some research. However, I might be able to do it by measuring the current when I apply a specific voltage. I won't have an actual water % value, but I'll have some values I can compare between the multitude of fluids. I'll run some vague calculations later and see if I should be able to read any reliable amount of current. These calcs will be based on some values I've found for other oils, and see how close I'll need my terminals together. From memory I can get down to 1pA accuracy on the DMM. I don't think my IOT Power Tester has any better resolution.
