Speaking of a bottle of Bourbon Nick......John Munroe and I knocked off a home brew bottle of Bourbon tonight in front of a nice bonfire.......nicest stuff I've had in a long time
Thanks for the pizza too John :cheers:
  • Replies 3.6k
Posted Images
Haha I had a sniff of this bourbon yesterday afternoon - smelled the goods!
Last home brew Bourbon I had was close to 70% and nearly sent me blind :turned:
hey pete, think its time for a sig update to a girly truck isnt it :P
by the way, thanks to all that showed up last night. The only odd things to wake up to this morning was two temporary no standing signs in my front yard >_<
went to the g1 drift at lala today and found some respect for sliders definately a fair hunk of skill required for those entry speeds into corner 1 :worship:
but mind u the corolla wagon was the highlight for the day putting on a killer smoke show on most corners
Anyone else here into the Arctic Monkeys? Just listened to their "whatever people say i am, thats what im not" album, so good!
yup i got side stage at the thebby gig back in 2009 i reckn it was but iam a pom so iam into that stuff :thumbsup:
Anyone know of a cheap shitbox car, ute or van for sale. Doesn't matter if it has mechanical problems on whatever, I can sort that out. My Stag and the wfie's car is starting to look filthy with our treks to the horse stables, and picking up food supplies for our horse. Wouldn't mind a hack that we couldn't care less about cleaning. An R31 would be perfect tho :P
speak to Ryan
31 wagon
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
