  • Replies 3.6k
Posted Images
I run a high flow metal cat in mine, seems to do the job nicely.
That said with the old decat in it did pop some big flames,
And that's what the kids seem to want these days.
I've mad a couple for the lads at work for their cars when they go to the track. Personally I'd just have a full track exhaust and a street exhaust if track days were my thing!
I don't fancy the 5 figure EPA fine for not running one.
I have a cat + 2 f**koff big mufflers and it still pops flames.
Myth in SA. Never heard of anyone getting a fine for it in SA.
I run straight through a gutted cat and twin 4" blast pipes on an SR.
Annoying and loud.
Yep definitely a myth.
That said I'll happily make them for anyone, I won't fit them for people, that's their responsibility and their head on the chopping block.
My car pops flames with the metal cat for sure, but they were alot bigger with the old decat fitted.
Plus it does make a bit of difference to the note/sound of your car, the 2 lads at work with s14s def sound alot more tractor spec with the decat fitted.
Kind of a myth. You will only get the $10k fine if your a business.
The fine for an individual is only around the $500 mark; but since cats can die after 25,000 km's if your running overly rich and definitely will be on it's last legs after 80,000 they have a tough time proving that you knocked it out yourself. Decat though is hard to argue but you just say "what's a cat" and then claim it was on there when you bought the car. End of the day unless your caught with a crow bar in the cat your not getting fined.
Dave if your popping flames through your cat it's only a matter of time before you melt it, and then it'll either block up or break up and shoot out the back.
Edited by D_Stirls
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
