  • Replies 3.6k
Posted Images
Currently doing the 4g roll out on all existing towers at my new work, you probably won't see proper 4g Australia wide for another 12 months. They might release 4g phones now but they will probably just run at 3/3.5g
hey mate, you don't happen to know a guy named Aaron Garard by any chance?
Nope? Who's he work for? I work for a little company that is sub contracted by a company called VAS who was contracted by Ericsson who is contracted by Telstra to do the roll out. Makes it interesting when you have 3 different companies with 3 different ideas on how a job should be done.
He is one of the head guys at Ericsson doing the 4G rollout - he is always heading from state to state overseeing towers and operations.
Not dissimilar to having a wife though Jarrad :-)
So I'm half way there? I think those lock nuts added a few KW this morning ;)
p.s- I'm taking those wheels off you soon.
Ah okay. Only been there a week so I only have met two site controlers. I work for JD Communications, apparently we're knocking the towers out faster than any other contractors.
Yeah its sad to hear, just goes to show it can happen to anyone. I do not know any details, but I'm assuming it happened on the roundabout, which is a slow speed roundabout really. Used to drive through there every day back in my Banksia Park High days, lol.
ok F&F Fans start making plans
Fast & Furious 6
Release Date: May 24, 2013
Studio: Universal Pictures
Director: Justin Lin
Screenwriter: Not Available
Starring: Vin Diesel, Paul Walker, Dwayne Johnson
Genre: Action, Thriller
MPAA Rating: Not Available
Official Website: Not Available
Review: Not Available
DVD Review: Not Available
DVD: Not Available
Movie Poster: Not Available
Production Stills: Not Available
Plot Summary: The cast of "Fast Five" is back perpetrating another heist.
Trailer:
Coming Soon!
    • Dort sounds above 3k rpm are dorty 🤣 I might krinkle black the alloy 🤔
    • It makes you wonder, all these people starting to make a billet replacement head, I wonder if any have thought about trying to adapt tech from newer engines into them. You're already at the full design stage to make a billet head... Why not really spice it up and had some more modern tech into the mix too...
    • Connect all the plumbing up properly. The actual worst part about having the turbo unable to actually build boost, is you can and likely would over soon the turbo if you drove the car (free rev while stationary isnt likely to manage it).   If you do have an air leak as Duncan suggested, you'll have a bad time as the AFM will be saying different to reality.   As you have had the engine out, I'd go over all electrical connections again. If you have a consult cable, plug it in, and see what the ECU thinks is going on. Did you touch the timing belt? If so, double check your timing on the gears is correct AND put a timing light on it while it's idling and see what ignition setting you have. Is the AFM you've installed the one that was in the car previously? You said you replaced seals, what seals exactly? What have you had apart?   From memory when I had my RB25DET with factory throttle, there was two plugs the TPS plug on the loom could go to. One would leave the car running like shit, the other made it work, I think one plug on the TPS area was for something else (an option). It's too many years since I saw that part of the loom to remember properly though.   Is the car idling smooth (as smooth as an RB can)? Does it smell fuelled up?   I have a feeling either timing in timing belt is off, or a sensor isn't right.
    • Theres still skid pan and motokhana days up in QLD at least that are $100 or less. The ones that are ran as "driver training" less so, they're expensive, but just normal skid pan days like SAU ran are still low cost. And thats one of the places I learned to be a lariken, purely by asking for passenger rides, and how people were doing crazy things. Reese gave me plenty of pointers back in the day for skid pan! And yes Duncan, I will never forget your pointers for track work. Especially after Neil got out saying "I am NEVER getting in the car with him again!" 😛
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
