  • Replies 3.6k
Posted Images
Boof, didnt realise u were dealing with ETSA projects lol. We're at port wakefield for the Pt Wakefield - Proof Range 33kv upgrade till next thurs........dont panic if anyone sees the Patrol drivin around with a female at the wheel, ive lent it to a friend
Neither did i till i opened up the curtains on the taughtliner and seen etsa stuff in there...
You know you're pining for your car when you hop on RHDJapan and order some nismo wheel nuts & nismo lm gt4 centercaps ...
.. especially for your car you haven't seen in well over 4 months because of an accident :( ..
.. gotta keep tellin' ya self - it'll be back soon .. it'll be back soon ..
Edit: can't decide if I added the nismo vinyl down the side if that would be going way too ricy or not ..
Crane photographer?
Not quite damo, crane operator to be precise :D
Also jenna if you like the nismo garnishes, slap em on there i say! Well, dont just slap them on.. Bad panel gaps are more rice factor than subtle styling mods.
well i have basically sold my 350rwkw R33 Skyline to an interstate owner, im gonna be missing her dearly, she was 100% reliable and never broke down, after collating all my receipts ranging from a forged engine rebuild to 3 turbo setups and lots of other crap im too scared to add up the total, it just goes to show u will NEVER get what u think for your car no matter how much u have spent on it
i was fortunate that i did not have to advertise it at all and not have to deal with wanna be test pilots
Not sure Jenks, but you should DEFINITELY be in on the trip to Vic for the SAU Nationals - hundreds of the best cars in Australia converging on Winton and Shepparton - get on it!!!!!!!!!!!
the wait is on for my new Samsung Galaxy S2.
It arrives sometime next week :thumbsup:
Bloody great phone. Typing this using my s2 right now, only had it for around 3 weeks. Fast, flawless performance. You will love it!
Had a little project to do with my Stagea over the last week or so customising from mounts so a rear GTR sway bar would fit comfortably.
Anyone in SA with a C34 Stagea thinking of fitting GTR sway bars to your Stag but are put off by the 'forced' fit of the rear bar, check this link out.
I've posted the details in the Stagea section ... link below:
http://www.skylinesaustralia.com/forums/topic/375348-upgrading-sway-bars-to-stagea/
:thumbsup:
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
