  • Replies 3.6k
Posted Images
Enkei's arnt fakes. They are not trying to be something there not an are high quality,
Cheap wheels are fine so long as they are not trying to be something they are not. replicas are what ticks me off.
Does this go for everything or just wheels? Say the likes of kit cars? Not the real thing but a replica, and in some instances better than the real thing ( so im told )
Te37's, unlike shelby cobras are readily available, so no not really, its a different situation
Cheap wheels are sometimes fine for posing around on the street, however if you race on them, be prepared to possibly die or stuff it in the wall.
Having said that the number of fakes I see on the dyno that are basically buckled square from hitting tiny ruts in the road daily driving etc is frightening. There are no standards in this game of knock-off wheels, just the temptation to make them as cheap as possible to maximise margins. Thats the price some will pay for vanity.
That's why I use Rays Martin as you know, on the track safety is paramount, I value my life an wouldn't want a major wheel failure at 200km/h
Either needs to hold 240 ish need one cheap utill I can buy somethin decent as I got a drift prac cuming up with low cash so will take what I can get
what engine have you got R34 in a 34 or a neo engine gearbox in something else
poor man pays twice, why not get a reasonable clutch right from now and sort the rest of your shit out after
i can get a good clutch at a decent price just all depends on what you call cheap to quotes you may have received from other places
hey mate neo engine and box in my r32 drift car.mainly after something cheap as i wont have cash to buy something decent before my private day was going to wait till it dies so i can atleast attend and do a skid or 2. im not going to spend anymore then $1000 on clutch. If ure able to get me some prices on and array of a couple clutches would be awesome and highly appreciated
the number of TE37's that ive seen cracked lately from driving around on our shitty roads is also quite high!
mate just get what i have in mine. NPC 10 inch clutch. it is bullet proof and so driveable. wont cost you anywhere near 1K either.
+1 I can also vouch for npc clutches, got mine from madaz and simon installed it, i went the 9.5 which is about 100 bucks cheaper than the 10 and its really not that bad at all, no probs in traffic and can handle punishment, so overall great bang for buck clutch, get a quote from madaz
    • I’m only posting this cause I thought I had seen a bad review on these somewhere before. Any feedback? Would you guys recommend that if I do buy these I send em to RC to have em checked before installing. Or any other suggestions?   https://www.ebay.com/itm/114009965865?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=JDl-15yLQ8C&sssrc=4429486&ssuid=QTzlFXB1S-S&var=&widget_ver=artemis&media=COPY
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
