I'm trying to fix my harness in properly and having some troubles. Anyone know where I can get or have made a 10 x 1.25 pitch eye bolt? Very much like the link following
http://online.covent...section=3215688
try probolt australia
or coventry fasteners in town
  • Replies 3.6k
Posted Images
who do u have to get ya misses to blow to have a shot :rolleyes:
just found out today the simulator will be at the Life FM open day you can have a free shot and say hello to Mark let him know your on skylines australia and Steve said to meet him
http://www.life.on.net/index.php/len-and-pete/48-general/150-life-fms-big-bbq-day
no probs Andz.
had full 100k service with gates belts, som exhaust mods including screamer, new coilpacks cos the JJR's shat themselves, adjustable cam gears with clear cam gear cover, carbon air box, carbon valley cover, silicone intake pipe with apexi power intake, plus all the gear still on it when i sold it.
No links yet, facebook based only at this stage.
on another note, who knows if R34 GTR fenders fit a GTT
They will, but won't line up with a GTT front-bar. I also suspect the inner-guard liners won't fit right either (not sure if GTR guardliners would fit, but I'd assume so).
Of course, if you fit a GTR front-bar, it won't work with the GTT bonnet - and then you need to change the bonnet, latch assembly (bit that holds the horns, bonnet latch, etc), the bonnet latch itself, and the hinges over to GTR items.
yeah anything GTR onto the front of a GTT basically means front end conversion. unless you buy fibreglass gtr guards that are made to fit GTT, same with front bar
I have a new body kit, bonnet and front bar for GTT only , but looking into a carbon Z tune front fenders marked for GTR
Edited by Carbon 34
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
    • Should have taken that opportunity to slot in a twin scroll turbo setup. Maybe next time.
