  • Replies 3.6k
Posted Images
I've heard something to do with the diff bush giving out and gearbox can if iffy.
+1 to this. My brother in law's 01 BA xr6t (in the 12 months he owned it) chewed up a diff and a 6 speed gearbox. It was 330kw+atw however
all the above issues were fixed with the FG Adrian.....if you can afford a 2008 FG XR6T, that's the way you should go..........with the ZF 6 Sp Trans
except for the issue of chewing out diff bushes.........my mate's G6ET is on its second set of brand new bushes in 12 months :wacko:
yeh fords are shit stay away :laugh:
if u half know how to maintain a car its not a issue , if u choose to leave 200,000km old diff oil in and rip a billion skids yeh itl let go whats new, most of the issues related to the boosted flacon are due to dip sticks not looking after it or just expecting the trans oil to last forever and tow a 3tonne boat daily :spank:
if ya intrested in the so called boosted falcon jump over onto the fordxr6turbo.com.au website and have a read horror and miricle storys all over the place :ninja:
hot tip the newer xr6t u can afford the better it is period :thumbsup:
Edited by JETURBO
I was an advisor for Jarvis for a couple of years, the early BA XR6T are honestly rubbish, 4 speed auto is a wate of time dodgy box, dont bother. They started getting it right with the BF MK11 onwards, if you want auto the ZF 6 speed is awesome and as SLED said the FG is great. Really nice driving car and pretty quick out of the box.
The BA has all the usual rubbish problems as any other BA such as;
Brake rotors
Dodgy 4 speed auto
Window regs
Diff bushes
PCM failures
BEM failures
ICC failures
And I'm sure there is many more but i tried to erase it all from my memory when I left
I would start looking at BFMK11 as a minimum
My dad had a BA and BF and both of them the interiors fell to bits, silver trimmings shrivled in the heat and the electrics gave out on the BA and the gear stick snapped off the BF.
They where both under 10,000km when it happend.
Nice cars otherwise :laugh:
Just spoke to dad and he also said he had PCM and bcm failures and the front brake lines needed replacing due to some dodgyness.
There was a rear brake hose recall because they were too short from factory, had many BA's towed in with no brake pedal :whistling:
The Territory had problems with the front hoses, and the focus had problems with the rear guard linings rubbing throught the hoses too lol
Happened to my old man, he was very lucky
for those going trackday tomorrow is BYO food and drinks people
I will have some variety of drinks and choccie bars there for sale for those that are in need ..... see people at 7:30am Caletex Bolivar (we will leaeve at 7:40am SHARP), or Mallala gates open 8am! It is going to be an awesome day!
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
