  • Replies 3.6k
Posted Images
You will find that some wheels just do not allow for normal nuts, Jose. Well in my case you couldn't fit a normal wheel nut as there almost no gap for the brace to go on. Hence why I changed to the Key hole nut system. Bought them for $40 for all 4 wheels with lock nuts. Have not had a problem with them ever.
i bought some WORK billet nuts, they were expensive. but with the Nismo rim's i've got they're the only ones that fit in the small holes.
i also use a thin wall impact socket, and i even have to take off the plastic outside to fit the socket in the hole.
the ones that came with the rims were in pretty bad condition, almost rounded off so i was due for some new ones.
around 60hrs in the withdrawal atm. feel pretty sketchy, anxious etc. too uncomfortable to sleep :/
got to go through it & just get past the next few weeks
once Im out the other side & past the addiction Im going to commit myself to actually being something
radiologist is the long term goal; have to dedicate myself to study. I know I can do it so its a matter of one step at a time.
yep suck it if u go to a organised event with a bunch of ferrals and dont expect to cop a sticker for ya fully sick vp dumped on its ass ,blind freddy could see that this was going to happen :domokun:
like it or not stereotyping is a fact of life and commodore owners just cop it .............didnt say holden owners cause thats not true ..............gazzanats cruise was on last sat night didnt see any defects there. and who wouldnt of worked out that last year they got bent over so what woud be different this year???? forget already?
iam a +1 for any charity work good on em but if u really thought that it was just gunna be a peacefull cruise u got to be kidding ,i mean i dont think they gave the cops enough credit all those potential defects in one place ud be dumb not to, talk about job done for ya pinch.gif
I was referring to pepsinators pics of cars after your comments - Scarlett naked is far more important thatn pics of cars ... :wub:
Edit: okay, I'm confused - got an email saying heslo said the pics were legit ... Was responding to that ... But doesnt seem to be here ...
heslo has just posted a reply to a topic that you have subscribed to titled "The Wasteland 2011 Edition".
They are her Jenna
Guest
    • Unfortunately haven’t taken pics yet after it was finished. All the edges are hemmed nicely, just had to cut holes for the gear shifter and seat bolts and seat belt bolts in the rear. The molds seem like they’re done with steam and a layer of glue on the underside to hold a bit of shape but still soft enough that it’s a good fit when it’s all pressed down.
    • When's the rear mounted turbo kit coming? Needs dose and V8 chop idle lol.
    • I was very unimpressed with how the car came up from the A pillar forward, before I hit things (twice). It all has to go. It had to go, but now it has to go... more. So we finally found the very first Shennanigans with the entirely perfectly setup engine that had no problems being pulled apart to improve on 'was perfectly fine'. Cam bearings looked a bit... stock. Which isn't entirely bad given they were stock and this is a ~20 year old engine. So new cam bearings are on the way because it's somewhat difficult to get to this stage to do it later, and it will trash the block. It was quite unusual that it wasn't done when the perfectly new-looking VCM cam was originally installed by [unknown] What IS unusual is the cam that was installed there was advanced SIX degrees. As to why there is no way to know.. however it could have been @Dose Pipe Sutututu's mate who wanted a larger cam sound but also wanted it to come on earlier to be more usable. This is my dyno sheet with the previous setup - This cam is not supposed to peak until 7000+ RPM, according to VCM. This is what lead me down the whole 'my heads/intake setup is running out of puff and can't support the cam' line of thinking to begin with. Anyway too late now - New cam is in! It could be rather funny if this smaller cam acts like a larger cam because it isn't advanced six degrees. In the spirit of everything is working amazingly - the COMP cam required no dialling in whatsoever. It was about 0.5 degrees advanced, which seems pretty bang on. Any adjustment either way would be further out. I'm told as a chain breaks in it ends up regarding back about 0.5 a degree as the chain breaks in, making it bang on. In the spirit of everything was previously working amazingly - The timing gear that was taken out turned out to be was an N-Motion double timing chain kit, with adjustable cam gear (which is how it was 6 degrees advanced) and all looks entirely perfectly new. It also had a Torrington bearing, which was one of the reasons I ended up getting the Cloyes kit which they used in the C5R 24 hour racecar - Because I couldn't confirm what was in the engine when talking to Tony Mamo. I did believe however it was a Double chain kit of some kind... but found no supporting documentation or evidence for it.
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
