  • Replies 3.6k
Posted Images
Who's got any recommendations on guard rolling? My mate is running 9.5s on his s15 and wants a bit more clearance on the rear. I told him I could do it easily but the results would differ from a professional job haha. Where should I tell him to take it?
Depends on what he needs done..to have to lip rolled up all the way I have had about 5 cars done at wheelworx and have been happy everytime. Most wheel / tyre places won't get the lip the whole way up. Wheelworx made their own guard roller and Joe knows his stuff
My guards were rolled by Scandyflick using a mallet and heat gun, far cleaner than many 'professional' jobs I've seen. Results always differ, but I didnt have any paint cracking.
i was gonna say, wooden or rubber mallet+heat gun+patience
All you RB20 people out there.
Brothers 32 is running abit weird. It has splitfires, 040, stock turbo, new plugs etc
When driving it, it hits around 38-4000rpm and cuts power (basically back down to 1500rpm then climbs again, then cuts)
I've checked the ignitor and AFM (borrowed others) and that hasnt fixed it.
The car doesn't get driven much so any help is appreciated.
Next step would be gap some new plugs (current is 1.1 or 1.2)
cant give Kudos Motorsport a more high rep
purchased parts a year ago and he couldn't supply the parts Andrew offered a full refund minus the parts he supplied and i said i would be happy to purchase more parts later which brings me to now
after deciding i didn't want to purchase more parts Andrew was willing to refund the price of the pars
very happy would happily use again
Try ignition pack, mate had a problem with his recently were it would drop revs and cylinders until he got a new one. If not I'm on the ECU train
Tried the ignitor and didn't fix it. Will try ecu, if that doesn't fix it been told maybe tps sensor.
tps wouldnt kill the throttle, tps is only there for response. if the tps is unplugged you can still run the engine
do you have a consult cable? I'd be chucking that on and seeing if there are any ecu error codes...
does the car idle OK?
-D
+1 steve. Ive only dealt with them twice but both times Ive been very happy in all respects
Guest
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
