Thanks again to Madaz for the NPC clutch he sourced a couple of weeks ago for me - its rad...
Picked the car up with the 33 S2 box and clutch fitted and did a hills run to wear it in. Have to get used to just how firm and precise it is but I finally have all my power going to the wheels.
Winning.
-D
  • Replies 3.6k
Posted Images
You'll love it ben. Try some hill starts in both forward gears and reverse. My pedal feel changed overnight about the 700 km mark.
Not a bad idea at all!
Also kudos to Shaun and Will at Boostworx for not only getting the job done on time, but they managed to come in under the price they quoted, in spite of having to do extra work. Great service!
-D
^gotta like that! Is that still a five speed box or was that the first of the six speeders Dohmar??
Nah its a 5 speed. Series 2 R33 GTR box (dual synchros tho). Still have many KM to make the gearbox lube up and unlimber. Every gear was stiff when I first started driving but now 3rd and 4th are feeling normal, 1st, 2nd and reverse are getting there, just need to shift in and out of 5th for a bit as theres a lot of pressure when I move the shifter to the right. I'm sure it'll go away in a while (box was stripped and cleaned in many fluids I dont even know the name of and reassembled with martini mineral oil used for the gearbox (not that blue shockproof shite!)
Box had to get converted from pull to push, thankfully BW has done it a lot and they have their procedure down pat...
-D
Inspiring conversation with Matty S this afternoon - you sir are indeed a champion !
Thanks ever so much mate. This world would be an amazing place if there were a few more decent beings like yourself around......
Hold your head high and be proud :cheers:
$860 del. from usa-ebay for Tomei type A or B, to suit Neo Rb25
$205 del. from usa-ebay for Cometic MLS head gasket to suit Neo engine.
A good place tog et stuff from is Raw Brokerage, if you arnt keen in ebay purchases.
www.http://rawbrokerage.com/main.sc
hope that helps a little.
yeah i was the fastest in it last (run) simulator event night
its as close to racing without being in a 100k+ race car
there is a weight limit of 90kg based on the seat actuators obviously he could put bigger in but then the build cost blows out
such a shame
thoughts are with Colin Edwards and Valentino Rossi too........they must be equally as gutted having been involved in such an unfortunate accident. 2 motorsport deaths in a week, such a shame :(
who do u have to get ya misses to blow to have a shot :rolleyes:
RIP Simoncelli, one of the most exciting riders to watch this year. live footage is pretty upsetting
He will be certainly missed. Was very sad when I heard that in the news this morning :(
well i tried to run another full blown event but wasn't enough interest so i canned it
Hey I am keen anytime :D
I'm trying to fix my harness in properly and having some troubles. Anyone know where I can get or have made a 10 x 1.25 pitch eye bolt? Very much like the link following
http://online.coventryfasteners.com.au/OA_HTML/ibeCCtpSctDspRte.jsp?section=3215688
-D
I use Redline in Everything, the Blue smurf blood, shockproof isnt supposed to be used in gearboxes, unless specified(some front wheel drive cars ) , it will damage your synchros since it reduces friction so much the synchros smash . you need to use MTL or 90 weight Redline oil I dont know how many people dont listen to proper advice and blame a product for the failure.
call redline in oz, great people to deal with.
I use 140wt Smurf Blood in the aftermarket LSD. and it lowers the temp a lot and hooks up in a instant, way better then the nissan oil, or synpower crap.
and MTL on my trans,metal part of the shifter never even gets hot now. !!! and synchros dont clash as before , had synpower for a few hours before dumping that out
Guest
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
