  • Replies 3.6k
Posted Images
Spewing I can't make it to the Riverland show this weekend guys - have fun!
Between a wedding this arvo/tonight (I will think of you all while at the open bar at the Stamford Grand Glenelg tonight :P ), pre-organised lunch catchup with friends on Sunday, and using up several leave passes with the wife to head to the SAU Nationals, it was just not possible :(
I am already doing the groundwork and saving up leave passes to be able to go to the SAU Nats next year (given it will be a 5+ day affair) ....
Dan I think you will find that the peeps are meeting up at the usual meet spot up north at 2:30ish pm and leaving around 3pm to get to Berri around 5-5:30ish pm.
Give the cars a bit of a wash and than booyah drinking time :D
There is room in my car if you wanna tag along mate, you will just have to hike in the back seat.
Guest
    • How to wreak havoc at a bogans party... Swap out the goon bag hanging from the clothes line with oil bag... Watch chaos ensue during Goon of Fortune....
    • Hey everyone,   I’m looking for some advice on replacing the timing belt on my RB25DET Neo-powered 1998 Skyline. The engine was fully built about five years ago, including a fresh timing belt, water pump, and other essentials. However, since then, the car has only covered around 2,000–3,000 miles. It’s currently making around 650hp.   Even though the mileage is low, I know timing belts have a time-based lifespan too, and most recommendations suggest changing them every five to six years or 50,000 miles. Since I’m at that time mark, I’d rather not take any risks and plan to swap it out soon.   A few things I’d like to hear opinions on: 1. What’s the best belt for this setup? Should I go with an OEM Nissan belt, or is the HKS fine-tune a better choice given the power level? 2. Would you bother replacing the idler pulley and tensioner at the same time, or only if they show wear? 3. When swapping the belt, is it necessary to lock the cam and crank gears in place, or is lining up the timing marks enough? I’ve seen different approaches, and I want to make sure I do it right.   The water pump was changed with the rebuild and isn’t run off the timing belt, so I don’t see a need to replace it again. I just want to make sure I approach this the right way.   Any insight would be much appreciated. Thanks!
    • How does this compare to the internally gated g25-550 in terms of power production at same psi and spool
    • Did you find that your voltage of the battery wasn't where it's normally supposed to be? for example on my r34, it's at 14.5v when running after a few seconds, but I noticed when I had a rough start and it initially wasn't idling correctly, the voltage on my triple gauge cluster was showing lower than usual. Seems like the alternator is starting to crap itself
