Looks awesome Nick! Did you do the graphics for it? (I am assuming you did).
Unfortunately not,
I did all the initial art work with different sponsors (Rocking Angel which is our Bourbon).
It only got the call up to allow it to run at the last minute so they got the vinyl cutter to put something on, especially after they did the whole chrome wrap on the car
  • Replies 3.6k
Posted Images
Any blokes who can help with some lifting and positioning of floor frames at my place say 2pm tomorrow in the Mansfield Park area? There's beer involved.
3 weekends now getting family/friends to come around and help with no results. Ready just to lift the f**king things myself and do my back in.
Got heart attack?
Soon!!!
-D
PS Whiplash mines the wild "t.u.r.key", lucky and little creatures. Rest are the other lads ;)
Ps Spam filter is wak.
EDIT - Heres the recipe btw http://www.bbqaddicts.com/blog/recipes/bacon-explosion/
same colour as my mates one.........surely one of yas would remember it........even if you do remember it for the wrong (transformers sticker on bootlid that he didnt put there LOL) reasons
does need a good home, and has lotsa goodies. also needs to do a good hillsie
PM sent regarding TME
Nice fridge there Ben .... sorry I couldn't make it - a leave pass from the missus 2 weekends in a row is tough enough (was in Melb last weekend), without throwing Kadina in a couple of weekends time in the mix too.
The Guiness must be Pat's I am guessing?
For any of the Northies, I am again workig on the 35 today, so if anyone wants to come help/watch/drink/talk shit then you are welcome. If you know where I am live, you are invited. Thanks for Brad and Pete's help yesterday! Got the front suspension changed, front adjustable sway bar on and braided brake lines done and bled. Today is the rear end. hopefully will have time to fit the new rear bumper bar too.
Thanks for the kind words bud but I only recall offering you abuse....not help :P
..........and yes, that car is def a favorite of mine............if only I had the cash :(
And yes I was going to say what did Pete do to help? But then I remembered he pumped the brakes.
Are you going to be around wednesday afternoon. Ill come and hook the shed up before tea.
David and Pat both brough guinness - fridge is happily empty now!!
-D
I'll make time for you bud.........I'll give you a call later.
Yes, my email notifications are not working also Steve .... I assume something is wrong with the system. I thought SAU had gone offline for a day or so there given my lack of email notifications ....
Guest
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
