Does $110 seem abit much to get just the 2 front windows tinted?
sounds pretty cheap to me. At my work it's $375 for a full car, or the same guy does it at hone under his own business and it's $250 for a full carthumbsup.gif
  • Replies 3.6k
Posted Images
the place i had mine done bent the rail inside the drivers door so my window ended up falling down inside the door about a week after the tint was done. the tint was ruined too.
Here's something that should interest all "L" & "P" platers.
Just saw a show on Chanel 9 where a kid blew .015 and insisted he had nothing to drink (zero tolerance obviously in his case).
Proved later that he was affected by his drunk mate passenger....just by inhaling the air that his mate was exhaling in the same car.
So the moral of the story is, if you're an "L" or "P" plater, don't kiss drunk chicks (or blokes) and stay away from "close talkers" :cheers:
asif u would kiss ur mate if u wernt drunk tho :nyaanyaa:
I only ask because I'm used to paying less then $200 for an entire car where as I'm only asking to just get 2 windows done now.
Booked in tomorrow I didn't care about the price just asking to see if this was about normal.
^^ not sure but if you can find what your looking for at super cheap auto I have a gift voucher I would like to sell someone could buy and use on such a purchase
I guess it would depend if you're spray painting or just using some air tools and look for one with a 2yr warranty
edit Supercheap's website has some on the front page
http://www.supercheapauto.com.au/#HomeProductRotator
Federal 595-SS 255/40/17 $147.00 i have heard these are a very good street tyre
Krishy's mate priced me up a good price on these Bob Jane prospect
npz his name escapes me just atm im sure Krishy will be in later and tell us his name
lol
Good to hear that you were able to get a good deal with them mate. His name is Clint.
Just let him know that you know me and he will try and get you the best deal. No harm in asking for a quote :D
Anyone know where to get a good but cheap compressor? And what to look for?
Yeah as Steve-o said, depends what you are doing. If you do a bit of spraying and want a good spray gun, youll need a fairly decent compressor. put it this way, to get one of our good gravity guns, youll need at least 300 litres per minute free air delivery. Or a bit lesser quality, around 210-220 lpm
Yeah I wouldn't mind getting something with the ability to do spraying aswel as air tools. From what I can see Super cheap auto compressors only do around 180 lpm, I have kiij around the net though and people are talking about connecting two together if needed, which I suppose I could do but it would take up alot of space.
finally took the track pads out of the GTR last night.
the rotors have seen better days, the backing plate on the pads has all the paint flaked or broken off.
the tyres are shocking! 2 huge flat spots!
the front under guard is just zip tied on.
it at least starts easy, and runs fine. its sad looking at the wheels and seeing cobwebs connecting the brakes and wheels!
GTR definitely is in need of some TLC
Guest
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
