  • Replies 3.6k
Posted Images
Accommodation being booked tonight, in Munich for Oktoberfest :cheers:
Need to start drinking beer again (pitty i have been working so hard to get rid of this beer belly) so look out schutzenfest!
which is in 1 months today, almost time to start arranging the yearly SAU "responsible drinking" day - due to legal requirements around my liquor license i must 'preach' responsible drinking blah blah blah
Fwiw been doing some fuel consumption 'testing' before the e85 swap. over the last two weeks to and from work (stop start) the results have almost been identical. this weeks results with filling up today were i used 43L of petrol and did 397 Ks. A total of 10.8L per 100kms
Didnt think this was too bad considering the motors not quite stock. By comparison off the governments site a current SS Commodore uses 17.3L per 100, 370Z uses 15.2, Renault Megane Sport 250 uses 11.8
Interesting stuff
http://www.greenvehicleguide.gov.au/GVGPublicUI/home.aspx
Is that with or without an aftermarket ECU right now? Cos that sure seems pretty economical to me. I'm currently getting like 15.5L/100km (320km or so on 50L) on an untuned R34 with 3" exhaust, 10psi - just regular driving around town (It'll get 600km+ on 50L on the highway though). Planning to get it down to get retuned early next year for economy if nothing else. If I could possibly achieve that sort of economy around town I'd be stoked.
Yup, I understand why my fuel economy is poor - stock ECU - and it'll compensate with extra fuel. Which is why I ask if Jap_Star has a stock ECU. I'm guessing not, which gives me hope that I might achieve good fuel economy with a tune :D
If you can't get a Nistune for your ECU Jenna (some R34s you can, some you can't depending on what type/brand ECU is in it), then go an SAFCII. Had one fitted to my R34 with good results, and now have it on my V35. On the 35 the tune made an extra 8rwkw and flattened torque and all curves rather nicely. Obviously having a turbo and running rich you would see much bigger gains.
Yup, I already have a nistune fitted, unfortunately it's just still on the factory maps - I haven't had the $$$ to get it tuned yet.
Plan is to take it to Boostworx or Willall in the new year. Given the 182rwkw I hit on 7psi, with the 10psi actuator now in - I'm hoping with a retune power should jump to low 200rwkw, with better economy. That's the aim/hope anyway. :)
My '34 is finally getting where I want it - few major things left on my list are fitting the nismo 480cc injectors, fitting the HEL oil cooler w/thermostat (sitting in garage), and highflow the turbo (probably MTQ).
Thanks for throwing ideas and help out guys :)
mine went to hell once I fitted the new xforce cat. that little restriction from compliance cat to a full 3" or more from front to back , sent the fuel mapping wonky even after resetting the ECU,need to get my nistune ECU slapped in and tuned. and my actuator installed,
on a side note who down south can work on skylines and you trust , besides nissan and hp in a box, or grand nissan wreckers ? need my new clutch fitted and look at what kind of crap the other mechanic did wrong when they did the timing belt. before it eats it. belt is a gates kevlar racing belt.
does anyone have a Gates/HKS. or non factory belt on factory timing gears ? mine is making a shocking noise like its rubbing randomly , the car does have carbon fiber cover if anyone has issues with the cas not sitting flat because of the cover. the damn drive belts started sqealing this morning too, bunch of farking trained monekys cant even do the belts and hoses without drama
who can be recommended for nistune, dyno tune on the GTT down south preffered? I was told garage 7 ?
Edited by Carbon 34
Jenna my mate spoke with boostworx the other day and Shaun has a 5k old turbo sitting there he only want $1200 for it you should hit him up
Really wanna stick with an R34/OP6 high-flow if I can - my power goals are only 240-250rwkw. More chance to get through Regency without me needing to change back to a factory turbo .. Do you know what sort of turbo Shaun has?
That's about what I get in my dead stock R33 GTS-T. In regular commuting traffic my fuel economy hovers around 10.5 to 11 ltr/100km, on whatever the pump 98 RON is I get. And that's with a mighty 128rwkW ;D
WILLAL
its a no brainer really, plus club discount
Guest
ร—
ร—
