Troy sorry I missed your post the other day, I have used Kent brake and clutch on port rd they are very good and not that dear
Jenna sorry I have no idea for all I know its a high flow as he was saying to my mate for $1750 he could have the turbo and fitted so it must be a bolt on most Garrett require new dump pipes
  • Replies 3.6k
Posted Images
yeah steve @ racetech has a good reputation.
ash hobson at hackham classic perfomance dyno (chapman road, behind cottage lane) is good with skylines too, loads of good results, but probably not that cheap - drop in and ask for a price.
Jenna, Adelaide Turbo Services can make you up a GT30-based turbo with stock (fully ported) front/rear housings. Get a price from Bill Keen.
Andrew - with the SAFCII I would suggest to also add in an apexi SITC, so you can tune the air:fuel ratio along with ignition timing. Well worth it IMO.
Highly recommended :)
Willall is the go for all your tuning needs - no Disney dyno crap there - just no frills tuning that simply works. On a related topic - big thanks to Martin for tuning the tow rig, an excellent result!
Edited by Blue32
Jaustech at Holden hill are great if you're near that area. Anthony has done most of the work on my car and he definitely knows what he's on about, just have a look at his cefiro. Plus they're great blokes too
That's about what I get in my dead stock R33 GTS-T. In regular commuting traffic my fuel economy hovers around 10.5 to 11 ltr/100km, on whatever the pump 98 RON is I get. And that's with a mighty 128rwkW ;D
My economy is with it at 270rwkw, I actually got about another 50-70 k's per week by changing to a bigger turbo due to rarely being on boost
touch ur toes at ash'es but gets results
^^^ DOH! How many hours had he owned it when he did that?
2 and a half days. Might be a write off, a pillar is moved and floor is creased.
Supposedly he was just putting around and got t boned.
Considering I've already had 3-4 concerned phone calls from people asking if it was stolen recently, the young lad has been driving it hard.
So I doubt it wasn't partly his fault.
Steve Knight racetech in Lonsdale.
Has an AWD dyno too for any GTR owners down that way.
Def my pick for down south....more so for mechanical work than tuning........Troy, he'll be fine for your clutch change-over and belt replacement
ahhh, Martin told me he was going to tune the ZF in your Disco.......how have you found it compared to its previous tune and what gains did you make?
We gained 30+awkw to end up with 175awkw and more importantly gained 100% more torque - I'll default to Martin to share the results from the dyno........
As you know they are already quite grunty for a 4WD, but even more so now and it drives very nicely. Fuel economy should increase now too - test underway currently as I compare the usage on the current tank load.
thanks bud.....I completed a long trip with my Disco pulling a 3 tonne van and it did it every bit as easy as the LC200 which has an extra 1.5 litres and an extra 2 cyls :thumbsup:
Sequential turbo setup is what I'm putting it too (with the small primary and bigger secondary).....the new 3.0L is an awesome engine too......and doesn't burn oil like the LC200 either, LOL
Where is the meet point, and what time, matty? Maybe for me - got the kids, and me & the youngest have a bad cold.
Having said that, we're off in a moment to see Adelaide United vs Gold Coast with a mate.... my children havent been to a live sports match in a number of years (youngest was in a pram last time we went to a sanfl match) so it should be a good night, both kidlings are soccer players & are looking forward to it.
come to the T20 big bash on sunday brendan. even though i pretty much hate that form of cricket, i go just for the atmosphere, especially seeing as the redbacks win one every now and then
Guest
    • I wouldn't be concerned at all, other than to suggest having them flow tested when you receive them to confirm they are reasonably similar, and then put the highest to lowest flowing ones in cylinder 6,1,5,2,4,3
    • I’m only posting this cause I thought I had seen a bad review on these somewhere before. Any feedback? Would you guys recommend that if I do buy these I send em to RC to have em checked before installing. Or any other suggestions?   https://www.ebay.com/itm/114009965865?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=JDl-15yLQ8C&sssrc=4429486&ssuid=QTzlFXB1S-S&var=&widget_ver=artemis&media=COPY
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
