  • Replies 3.6k
Posted Images
Just wondering what ever happened to freedom of speech?...
Wilko, imho between your comments on here and your FB, you are acting like a bit of a tool.
There is no such thing as freedom of speech.
Everything you say on a public medium is open to scrutiny.
If you defame somebody on the forums, they can sue you.
If you express an opinion that the police take as deragatory/illegal, they can pursue you.
If they don't like what you say (and how you say it) on SAU, a moderator/admin can ban you.
I got a call on behalf of SAPOL asking me to remove references to what happened the other day, so I did it.
Quit pushing the envelope.
Also dyno night is at horsepowerinabox 8pm-whenever. Commodore club.
Who would be interested in a sua:sa dyno night?.
I just want a final power figure now that the misfire is fixed lol
Matty,
This is going to shock you...
... Doesn't technically exist in Australia. Implied, but not expressed per se.
Also by the way it's not specifically commodore club. Its a shootout between two clubs called "Madhouse Performance" and "Driven Never Hidden". Although there will be a few commodores there to say the least.
I'll be there in support of a friend. Should be a good night
I didn't like it that you called me a tool, (and how you said it)
Just saying.
I have been following your smack talk on here and FB, and I gotta say I don't like it one bit (go back and read what you have written and see if it is fair to me or any of the other guys who help run this place).
Tool was the friendliest word I could think of, and the nicest way of saying what I did. At least I am saying it to your face on the open forums, rather than whining where you think I don't read it. If you don't like the SAU forums or the club (and the people who give up plenty of their free time run them), then go find another forum/club. Easy.
That goes for a few other little bitches who do nothing but whine and knock the club behind our backs, yet do NOTHING to ever contribute in a positive way to the running of the club or its events.
Just saying.
For what it's worth, this is 'The Wasteland', and I am expressing a personal opinion. I am not expressing the collective view of the SAU forum nor club, merely replying to comments directed at me, the moderator and Exec group.
+1 that shit
if people knew how much running around we do to organise BBQ's, track days, dyno days, simulator event nights, go-karts, paintballing and other kool shit to come this shit just doesn't happen
little bit of respect (this is clearly not aimed at the people who do respect the exec team)
Guest
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
