  • Replies 3.6k
Posted Images
sled nice taxi ull be amazed how agressive the little turbo on the xr series pulls they max out at 320ish but thats the most impressive rollons ever with a zf u did get a zf didnt u ? or u go stick :rolleyes:
one of the blokes had a ego one 320 on tolly did a 12.2 @119mph but on the street got car lenghts on any of us at 60km/h on wards weapon 4 sure :thumbsup:
On the dyno with stock ECU I'm assuming? I've never checked to be honest...
Needs a tune pretty bad, getting an absolutely horrible amount of k's out of it.
There's no tuning that you can do with a stock ECU. The only thing that you can do it adjust the base timing at the CAS and anyone can do that with a timing light. If your fuel mileage has become worse then i would be looking at your O2 sensor.
Sorry bud, here you go:
Specs to follow via a Dyno Sheet next week when it goes to Willalls so Martin can work his magic
Really looking forward to this SLED. There are a lot of new techniques in the tuning of these cars that arent being implemented in South Australia currently. I know this as none of the SA Tuners attend the Australia wide advanced Ford tuning workshops....and I am the headmaster :)
Your tune will have 'all the fruit'
Also prob won't hurt if you changed the plugs and done a service at the same time, ie oil, coolant, filters, give your intake filters a good clean. That should get your car running just right :D
Guest
    • Only needed to pull out the seats, center console and gear shifter surround, took a weekend and a fair few beers. You get to look forward to finding all sorts of weird shit under the seats and carpet, I pulled out a Chinese dudes passport from 2003, 220 yen and a condom wrapper 😆
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
