  • Replies 3.6k
Posted Images
I know its a long shot but does anyone have a long drill bit/drill bit extension so I can drill down from my ceiling down the wall cavity through the timber studs so I can feed some wires through without having to cut the shit out of my walls. Would need to be about 1 to 1.2m long
trade tools direct have 2metre long ajustable drill bits for like $199 i reckn they were but if u do whative done just get a spade bit and a piece of threaded rod and weld it on the end and then shape the end for the drill bit all bits at bunnos for less than $50
if u really need i can hook u up with mine :thumbsup:
Working at a house (being reno'd). Got talking about cars to the tradies. Tradies say dude who owns this house just sold a couple year old gun metal grey GTR and got a newer one and the brakes are huge.
I ask if the plates are GUN 350 and they're like "How the hell do you know"...small world.
So you're doing some stuff at Walkerville .... I haven't been down there to check it out for a few weeks, but last I heard from John it is coming along very nicely. And would you mean this new R35 (with my wife and child in it)? :)
But have you seen the new Land Rover? :D :D :D Porn, I reckon!
I was going to buy my own but for a use once application I couldn't justify it. I was gonna go down the built my own route if no one had anything available but looks like I'm in the clear now!
And Steve, just doing a bit of cable management and running another powerpoint behind the TV
BLUEEEEEEEEEEEEEEEEEEEEEEE :worship:
hmmm there's an unsual sight [sKY350] on jacks :nyaanyaa:
which land rover, the new Disco or the new soft 4wd?
Give me a ring I have a few spade drills with extensions for going down the wall
Yeah did some gutter guard around the back verandah, where the verandah meets the house itself. Tell John if he wants the whole house done (which he should as they are chockers with leaves), get in contact with me. Looks like a damn nice house. How far off have they said from occupancy?
Didnt see any of the cars. Just one of the guys said enough for me to figure out who it was. He was memerized by the "big brakes"
Guest
    • I’m also conscious that e85 is slowly being phased out. Not all United’s have them anymore. Can’t take the risk of being low on petrol and assuming the servo will have it.
    • MR HAMMER has said his piece. Painted up to avoid Rusty Rusty. Actually lines up well. (i.e it lines up the same as the unmolested GTR guard). Turns out the GTR Strut brace does foul on the bonnet vents ever so slightly. May need a little bendy bendy if intended to keep using with a strut brace. So spacing it out to clear the FAST102 is not an option. Annoyingly, the bonnet vents also foul on the heater lines running over the engine. Given this engine does not EVER require a heater, a delete loop is going to be used. Don't worry, the defogger uses the AC. The heater is basically "Do not use the aircon and turn the fan on". It will still be effective, I promise.... once I get the system regassed... Will have to revisit with unvented bonnet I suppose, and suitable strut brace. There's plans to do this and other things tonight and bleed brakes (there was a weep) and put the bumper back on, and take Good Friday morning - Because troubleshooting on the side of the road limping it home at midnight tonight is ... not very smart.
    • Thank you all for you assistance. I contacted Nistune regarding the support for the RB20DE along with my ECU Code (23710-10U00). They do have a map for it and added the RB20DE as a purchasable option now as well. They also added Malta as a Billing and Delivery options as this was missing. I was honestly amazed at their quick response and action, it took less than 24 hours. I also looked again at direct fit options for injectors, just in case I were to replace them. DeatschWerks seem to use a Bosch EV14 base and makes ones that fit mine at 440cc lowest, but also have 550cc at the same price. I tried looking for other direct fit options and managed to find one (also Bosch EV14 based) which includes a plug and play adapter on ebay. Did a small test with a Noid Light on the troubled injectors and all seems good, so they are pulsing properly electrically. One weird part is that they are missing on the same two cylinders as before I got the injectors cleaned. Mechanic also found this weird as he did not label the injectors and it is unlikely to have the faulty injectors be installed in the same cylinders.
    • Nice, let me know how you find the 98 tune
