  • Replies 3.6k
Posted Images
If someone laughs at you for not making massive KW's then they have a problem. I say do it for shits and giggles and at the same time you can find out what your car is actually making :D
Who cares about power. I would laugh at him for owning an AU
OK..i have a big ugly caryard sticker on my rear windscreen its the chippy reflective vinal stuff :sick: .
I would like to remove it , im asking suggestions before i attempt this as i know it will get messy.
I was thinking of using Bug & Tar remover (worked wonders on the debadge.)
Please help.
Hair dryer / Heat gun awesome idea.
I did sort of try it but due to the type of vinal it chips off in vrey very small portions.
LOL.. This sucks may take a while :rolleyes:
Thanks for the help.
Stanley knife blade.
I know there's 8000 hicas threads but i think it's worthwhile to post a question on here rather than scour the abundance of info straight away. My hicas light on my dash has quickly flashed once on two separate driving occasions. I have no irregular steering symptoms but I have noticed both times it happened just after taking off (normal driving) and slight steering movements. The car was serviced on monday I figure it might be a bit of air in the system or something. Anyone got any ideas?
Hicas is not locked or bypassed all standard in that department. Will be happening soon though..
fluid sensor on ur powersteering. possibly needs a top up to cope with +ve g's
On another topic
Anyone wanna go to Burger Foundry?
Want to stab a dolphin in the face unless I get one of their tasty burgers....
save the dolphins. drive dohmar to burger foundry.
-D
Guest
    • Middle seat good for a slab of beer or Esky for a road trip. 2x kids, means 1x free seat lol.
    • So we have most the interior back in, and for the first time with one OEM speaker hooked up. The 31 is running, driving and now tunes!!! Hahaha yet another step for the sub that sat 10m under for two weeks!!! unbelievable really 👌 lots of love work and not giving up on her. Seen so many youngsters part way less, and in way better condition. I’m stubborn, thinking another problem is just a hurdle to overcome, One at a time. IMG_9277.mov
    • That is correct. I'm using a modified ABS ring and a ZF speed sensor on my rear diff for speed input. I'm running a Haltech ecu.
    • Been busy with the newborn. We originally thought we were going to go for a third, but we're good with two lol. He's starting to actually sleep now so I've had some energy to work on the car. It's been parked away in the garage since late November due to winter.  I went ahead and redid all my head oil drains. I originally had my front and rear head drain going into the same pipe but have since split them up. I also added an Ethanol content sensor to get ready to run E85 this summer. Tossed it on my return line. Sensor sits nicely under my intake manifold.    I also have a lot of parts that came in for my rear end. I'll be swapping over to a 3.3 final drive and doing the GK teck anti squat mod. While the rear subframe is off, I'll also change every bushing. We're planning on buying another house soon with the condition that I get at a minimum a 2 door garage, so I'll wait to have more room for this. Now onto the strange things that recently happened... After changing the lower rad hose (It had been sitting in my cabinet for well over a year and was the last hose I had to replace), I let the car idle in the garage to bleed my coolant. After running for a few minutes, it started missing. Got much worst within a minute or two and then stalled and would not restart. My crank sensor decided to crap itself. No damage, no explanation, just died. I went ahead and replaced it with another ZF sensor but the heavier duty stainless model with a shield. Tossed that in and started right up. Has anyone else seen this? I hate when things fail without cause. Luckily this was a blessing in disguise... This lead me to recheck my timing. It seems I may have had a beer or two the last time I had set my TDC angle as I was off exactly 5 degrees... I miscounted a line haha. I was running 5 degrees less then commanded. It's a little embarrassing but helps explain why my dyno operator seemed to think I should be making more then 478rwkws.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
