I dont see what the problem is with fake carbon, it still looks good, and if you wanna go and buy the expensive real stuff to save weight, youll know deep down inside your saving those few extra kilos.
  • Replies 3.6k
Posted Images
It was designed to be watched quickly though - didn't want to drag things on. It's not perfect, there's a couple things I would of liked changed but yeah...
I think its a pretty good job. Bit of plain information, bit of comedy (needed benny-hill chase type music when the IronChef runs after Miss.Fine); keep up the good work I say!
Yeah will defs go with that one
good price and looks tricks
no worries. also after looking at the link i posted theyre not the n1 ones i was thinking of
just jap sell those, $100 more so not really worth it
http://www.justjap.com/store/product.php?productid=17336&cat=&page=1
its not to save weight most of the time its just to have the real thing. next theyll be using the chrome wrap becuase its cheaper than chrome. doesnt bother me, gives those with the real deal something to chuckle about
Its good, I like it.
except for the random drifting part which doesnt fit in to the title
When is it your turn to co-host it?
What do you own that is 'genuine' carbon?
Guest
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
    • I'm mark from Idaho.
