The Wasteland 2011 Edition
Nightcrawler
 Share
  • Replies 3.6k
Posted Images
Its only a conservative little 13psi tune through the stock exhaust on 98 pump. Just a nice 'area under the curve thing'. Sled has the dyno graph :)
Just a little tizzy and tidy up then. Probably still more than enough
hey sled went to willall today for the commodores owners club dyno day mainline is hungry hungry but still delivered on the torque figure which i spose is good did 340 kw but 1087nm torque's had a good old chuckle with dingo and looks like i might in the near future have a looksee at all this zf tuning jargin hes banging on about more than likely ur car will be the first or one of the first to have it done to cant wait to see whats the g..o :thumbsup:
did i mention i dont like mainline hahahah thats the weirdest shit tho
the bloke who took out the day bosko(ba f6) reeled off 510rwkw on a d/d then 447rwkw today with a very same torque figure 1088nm i think it was but that would definitely be doing high nm @wheels running 24+psi through a 4litre
Hey Jet, I did expect you to drop below 400 but not a whole 80kw >_<..........that may explain your ET cause 421 should see a 10 ET.
Seems Bosko dropped a similar amount.........I'm guessing you guys had the original power figures taken off Heinrich's dyno, yeah??
Makes me think that if I can get get anywhere near 300kw on Willall's dyno, with a smaller turbo, stock cooler & exh from Cat-back, that'll be lethal enough for a daily :yes:
Mine will be on pump gas.........I'm guessing you guys were running E85 again on Willalls?
yeh original were off heinrichs 510-421 and yeh both running e85 as u said if u can reel off a 300 on a mainline its guna cut the mustard nicely. we have done some back to back runs across adelaide hpt vs k.p.m vs southern hi tek but they were all d/d and were showing very ball park figures but the mainline seems to be the differ
we all know the dyno debate but it just seems to be mainline is the most accurate might we say :worship:
Sorry guys, just got home.
Martin I didn't get the print out.......I think you ran out of paper and went looking for some. Can you email me a pdf of it please ([email protected])
Now, as per above past posts, I'm very happy with the tune and considering I'm running a smaller turbo than an F6 and pump fuel, 307kw is pretty much what I was hoping to get.
The beauty about this is that it's still like a stock car to drive around as a daily and not only looks like one under the hood but sounds like a stocker as well.
Even after 60kph, you definitely only want to feed the power in slowly other wise I'm going to have to invest in a Tyre Power franchise........absolutely love the down low grunt.
I'm betting that with another 2 or so (conservative) psi and E85, it'll probably see over 350kw........not bad for a daily Taxi that's very quiet and comfortable.
I'm very happy with the Willall tune and have learnt the hard way now as far as past tunes go; "The poor man always pays twice".....I'll never go anywhere else again.
Thanks again Martin........and for lunch :cheers:
Good numbers for only 13psi Pete. :thumbsup:
Sled the printout is sitting in the printer still, but will email you PDF this morning.
BTW nothing beats the Tai Ito Lemongrass chicken Banh Mi roll!
Guest
 Share
    • Looks like a healthy scene. You've had an R34 before?  What are your plans?
    • So here is local scene in my city, not much but we are always welcome for any foreign Nissan sport cars buddies!
    • Hey man Thank you! Excited to be here Mostly 4 doors ER, HRs not much of 2 doors, I personally know 3 guys that have coupes And yeah, they are some BNRs, BCNRs, not that much left, some of them went to EU.   Thanks, actually the conversion was done by previous owner, I wanted to get it even when it was 20DE AT cause the chassis was taken care well but getting it with MT turbo wasdefinitely an additional pleasure 😃
    • Hey guys   I'm pretty sure this question was asked before, I had an HR34 before, got another one again and I never gave much attention to this but wanted to ask you guys about dropping or pushing bonnet problem. ER, HR got pretty heavy steel bonnets, I'm sure S chassis and other R chassis gens also got heavy bonnets. I used to push it after I gently put it down on the latch but I saw some videos guys dropping it from 30-40 cm and some say it's more reliable way to make sure it's safely closed. I let it drop a couple times from like 30-40 cm and it's locked no problem but it gives me that bad OCD feeling after that that something is damaged lol, the bonnet rubbers is there, guess they handle that little fall energy well and the latch itself is what stops the bonnet right?  Talked to other Skyline owners, some say both methods are fine, some against dropping it by any means, some drop all the time no problem. So I'm like confused if I was doing it wrong or not and if I already messed up something. ...and jealous of my friend's Z, dropping aluminum bonnet feels so much right and better haha
