  • Replies 3.6k
Posted Images
so, i decided yesterday arvo itd be a great idea to go for a casual drive in the hills and see some mud
was about time to get it dirty. came down the hill alright, followed the ruts. Then the challenge got set....get back UP
first up was the "steamroller"
made it look easy as piss, but then again he does have a locker
Gus tried it out in the "Atari" Vitara. Got a respectable distance up but wasnt getting any further
My turn.......like driving an RB20, flat to the boards, take no prisoners
wasnt goin to let this hill beat me, so rolled back for another go
gave up, as i was getting stuck in the very last bit of the rut and risked burying my diff in if i tried with any speed
then the next guy attacks it.....gets to the same spot, but not to be beaten, moves one more rut to the right....shit tonne slipperier. Keeps going back for bites, until this
pics dont show it well, but it was super steep and slick as. Used the first truck's winch, only to find the "cheap chinese copy" of a good winch wasnt sufficient...the end of the wire thats meant to be secured to the drum was just floating............so once tension was on it wouldnt pull
Time to try mine out
3 hours later, god knows how many different pull angles, my winch rope bunched up and snagged, so we were destined to use only snatch straps to get out........bit of panel damage on the Maverick where it snagged on the tree on the low side, but we all got out
Now to clean all the "gorilla snot" off :rofl:
Scandy......think i need a new sig pic now :P
Guest
    • This has been covered a bazillion times but google wet boiling point vs dry. Motul is only good when it's fresh, once it absorbs moisture it gets pretty average very quickly. So as above, make sure you change it if you're going racing. I run the Endless brake fluid in mind, but only because a mate is a distributor and it's cheap. It's not quite as good as SRF but I'm running 380mm rotors on a Skyline so it's not like they get hot.
    • That's the thing, they still add it and it makes fuel cheaper, implying adding 10% of it drops the cost of 91 by what, 5c a liter? I remember when it was barely half the price of 98. Because you know, 85% of what is in the fuel is way cheaper than 91 fuel is by volume.
    • Auto electricians that do repairs on automotive AC systems can source service kits. I don't know where they actually source them. I do know that there is one available for the R34 comp that I would need it for. If you have to pay someone to dismantle, clean and do needed repairs and fit kit contents, then you'd probably end up spending a good fraction of the cost of a new one. I would not be paying for that, because I would be doing it myself. My mechanic (bro-in-law) will happily source what is needed. Back in the day (like in the 80s and 90s), rebuilding an AC compressor was the standard approach, same as for starter motors, alternators, etc, because new replacements were v. expensive. After the China manufacturing boom and the rise of the disposable approach to everything, people just started throwing broken/worn stuff away and not rebuilding things.
    • Is rebuilding it even a thing? Where would the shop find parts for it? I looked at some off these local online stores for my r34 and suprisingly they had brand new aftetmarket ones for $600-800 I think. I guess r32 might be a bit tougher.
    • I remember the days when E85 was priced in according to the $ per km outcome. Sure E85 was about 35% cheaper, but you also lost about 35% range... now it's fked..
