  • Replies 3.6k
Posted Images
How much and where from matty? Ive been looking at the whole kit lately, hopefully it might resolve the choo-choo turbo shuffle the -5s have
Kudos Motorsport pete. The suction kit was a tad over 1300 freighted from qld. Hard pipe kit installed last week was 650.
Somehow I dont think its the boost flutter you have to worry about pete (stock wastegates ftw) :whistling: You still attending the dyno day? I can't wait to hear your 33 at full noise in the shed :D
Yeah I'll be there don't you worry.
Does that suction kit fit your stock afms or only z32s?
Aaah should've mentioned that... I got the last kit from kudos that is compatible with stock afms. The rest are Z32 jobbies.. I'm gonna cheat and use nismo items..
It might pay to have a bit of a google and find out which brand you prefer the look of mate, some people prefer the HKS kit, good luck finding one in oz though!
Only problem is now my inlet plenum would look much better chromed and polished, looks like my stealth engine bay approach is dead :whistling:
Anybody know the best place to buy a Nistune for series 2 rb25 r33? An do you need to supply your own ecu or does it come complete to bolt in?
I didn't think these were supported, so I checked their website (http://nistune.com/equipment-products-type2.php):
• ECR33 Skyline (RB25DET)*1
*1 ECR33 RB25DET Skyline can use HCR32DET ECU (no VCT) or Z32 VG30DETT ECU (internal modifications required)
So yeah - R32 ECU if you don't want VCT, or Z32 ECU if you do.
Yeah nismo afms is what I'm running too hence why I mention it. I think I'll probably just import one when the time comes. It's good to know it works with the stock size ones though, I couldn't find any info about it on trusts website.
Sorry pistol I may not have explained that properly. The greddy kit comes in two variations: standard afm and z32 afm compatible. I managed to snag the last one on kudos' shelves that retain stock items.
That way I can run nismo afm's later on if need be. try www.rhdjapan.com .... never fails :)
So you bought two separate kits, the intake and the I/C piping? Thought they came in one kit?
Yep seperate kits. The "Hard Pipe Kit" replaces the factory rubber i/c piping. The "Suction Kit" replaces the factory intake piping and airbox. A smidge under 2k sent to my door..
yeah thats what i wasnt sure of as i hadnt been able to find anywhere selling the standard size version, even rhdjapan
Guest
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
    • Dort sounds above 3k rpm are dorty 🤣 I might krinkle black the alloy 🤔
    • It makes you wonder, all these people starting to make a billet replacement head, I wonder if any have thought about trying to adapt tech from newer engines into them. You're already at the full design stage to make a billet head... Why not really spice it up and had some more modern tech into the mix too...
    • Connect all the plumbing up properly. The actual worst part about having the turbo unable to actually build boost, is you can and likely would over soon the turbo if you drove the car (free rev while stationary isnt likely to manage it).   If you do have an air leak as Duncan suggested, you'll have a bad time as the AFM will be saying different to reality.   As you have had the engine out, I'd go over all electrical connections again. If you have a consult cable, plug it in, and see what the ECU thinks is going on. Did you touch the timing belt? If so, double check your timing on the gears is correct AND put a timing light on it while it's idling and see what ignition setting you have. Is the AFM you've installed the one that was in the car previously? You said you replaced seals, what seals exactly? What have you had apart?   From memory when I had my RB25DET with factory throttle, there was two plugs the TPS plug on the loom could go to. One would leave the car running like shit, the other made it work, I think one plug on the TPS area was for something else (an option). It's too many years since I saw that part of the loom to remember properly though.   Is the car idling smooth (as smooth as an RB can)? Does it smell fuelled up?   I have a feeling either timing in timing belt is off, or a sensor isn't right.
    • Theres still skid pan and motokhana days up in QLD at least that are $100 or less. The ones that are ran as "driver training" less so, they're expensive, but just normal skid pan days like SAU ran are still low cost. And thats one of the places I learned to be a lariken, purely by asking for passenger rides, and how people were doing crazy things. Reese gave me plenty of pointers back in the day for skid pan! And yes Duncan, I will never forget your pointers for track work. Especially after Neil got out saying "I am NEVER getting in the car with him again!" 😛
