the only reason i want to do it is cuz my aftermarket ones dead and some indication of how much boost im running is better than none. the main thing i need to know is where do the wires connect to the stock boost gauge? is if located behind the dash?
If running mroe than stock boost, with stock boost gauge is just as helpful as you dead aftermarket one.
if you can hear hissing its vac leaking
ie venting to atmo
which is likely to be unlimited boost mode
stop what your doing
see someone who knows what they are doing before you run unlimited boost and kill the turbo
find a local member with a GTST to give you 5 minutes of guidance before you break something
