Hi all,
I have an r32 gts and it makes a sound coming from around the bell housing.
It makes a noise similar to the sound of a spun bearing.
The noise only occurs when the clutch is out and stops when the clutch is pushed in.
Wondering what is causing the noise The Thrust bearing or the gearbox input shaft bearing?
Hi all,
Input shaft bearing. When the clutch is disengaged, the input shaft stops turning, stopping the noise. Release the clutch, shaft turns, noise returns.
This is all normally true diagnosis^
However, some thrust bearings in Skylines produce a noise even in neutral with the clutch out, because they rub up against the pressure plate in the resting position. Try putting a little bit of pressure of the clutch pedal, i.e. don't push it in, just push the pedal until it gets to the point where you have to start trying. If the noise goes away, it'll be thrust bearing. If it's still there, most likely gearbox rollover noise which can be an input shaft or the gears simply meshing incorrectly (happens with age and wear).
It makes the noise in neutral and when driving (can't hear it much cause of loud exhaust :) )
birds, ill check with the clutch only slightly pushed in like you said. I hope it is the thrust bearing cause i really can't be bothered replacing the isb since I am planning on putting a turbo motor and box in within the next year or so.
True
And being a hydraulic clutch, there'll always be contact, as the slave cylinder "self adjusts". Another method is to hoist the car and pull the clutch fork (depending on whether it's a push or pull type clutch) away from the diaphgram spring, taking the thrust bearing with it...
  • 4 months later...
  • 5 months later...
I also have a similar noise in my GTR. I only got it about a week or two ago, so still learning as much as i can about it.
My one makes a noise while I am in netural, once i press the clutch in. It goes quiet. Take it out, the "whirring" "whine" noise comes back.
A friend said its a thrust bearing, but from reading the replies in this thread i am confused and not sure.
Anybody know if it will do my car any harm?
General consensus says you need to take out the gearbox to fix it, so i may as well wait till i need a clutch as long as it isn't damaging anything by waiting.
the whirring is the thrust bearing, perfectly normal. i recently replaced my clutch and thrust bearing and the whirring noise is there just as it was before, i also think its got something to do with my r34 and your 33 gtr being pull type clutches im sure someone else can either confirm or correct me on this.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
