wrecking Nissan skyline r33 gtst 1996
lots of parts available just ask cheers
motor rb25 det series 2 complete $2000 ( low kms 76,000 can hear running)
gearbox $1500 ( low kms 76,000)
pedal kit $200
tail shaft $200
flywheel $80
diff lsd $300
cv joints $60 each
stock springs & shocks $250
tein coilovers $1200
cannon with hi flow cat turbo back system $400
brake master cylinder $80
front calipers $250
front disks $70
rear calipers $150
front hubs $100
rear hubs complete $300
upper control arms each $30
lower control arms each $70
cross member $100
rear upper control arms each $25
rear lower control arms each $75
power steering rack $150
p/s bottle $20
Hicas $80
heater core $100
stock computer $150 (man)
speedometer $120
taillights $50 each
skyline tail light piece $100
power window reg $120 each
ignition barrel plus door locks $150
blinkers switch on dash $50
ac display $70
rear bar $60
rear bar reinforcement $50
rear pods $80
boot $70
boot shocks $50
doors $50 each
rear cut $600
beaver panel $100
fuel flap $10
fuel cap $10
skyline mats set $120
carpet $70
battery holder $20
washer bottle $20
radiator overflow $20
glass from $40
fuel tank $30
fuel pump $80
fuel lines $100
door trims $140 each (bare)
rear trims $80 each
boot trims $70
interior light $20
seat belts (all 5 ) $150
dash $80
dash vent and surround $80
seats (front & back) $400 driver seat is bucket (drift brand)
sun roof $300
antenna $50
call me on 0426504272 car is in Liverpool area
can post anything you want as well
Edited by anthony84
hey champ wats ya best deal on the strut brace, engine damper and the surrounds for the gear stick and dash surround?
Id be happy to take all the addons that are there, clock, switchs and vents n wat not.
Please PM me a price thanks.
Christian.
If you still have the CF gear stick surround, gear stick boot and handbrake boot let me know the price. I'd be keen at a nice price. I can pick up.
PM me.
Edited by simpletool
Pretty sure thats carbon fiber vinyl overlay. My car has it. Looks pretty awesome if applied correctly.
If anyone is in Sydney, give me your gear surround and Ill do it for you for $15.
    • FWIW a lot of the local owners that do a big build tend to have cars that are perpetually broken.
    • I just got this system but haven’t installed yet I got a Moroso sealed box (defect reasons) which will be set up same as their pic The quality is high grade, the correspondence I had with the owner (former head designer for Rockford Fosgate) was unbelievable, guiding me with what I needed. Even told me not to buy some things as it could be sorted in a different way at his loss. Just a bit of a bite with the exchange rate and don’t purchase gear in 1 hit that goes over $1,000 au, lol I forgot!
    • Thanks mate for that reply. Very helpful.    it’s a 2022 400R so would most likely lose those features as you say.     I did a quick compare of a rv37 nav and heading for sale in Japan to q50 model. I’ll pop pics below. Seems  Japan spec head into top, nav unit second below it   below pic Q50 aud delivered     differences seem to be Aus delivered has a different plug top left hand side of head unit- not sure what and where it goes.   and nav unit Japanese tv37 had an extra plug put    Again I’m really not sure what each of these differences mean!       the actual plugs on a v37 and q50 screens look identical on both screens… pics below for comparing. (One screen was is a us delivered one) but should be same gps signals etc as Australia.    If it were as simple as swapping a nav unit from q50 aud delivered im interested -just want to figure out what the missing plug is for before spending big $ on a second hand part for it to not work, and I guess with the head unit, if the band expander does the job (I got a 20mHz so should get the range I’m after) so should narrow my issue down to nav unit only.  I’d love to know what the extra cable on rv37 does and if I eliminate that part what it’ll do to the setup,    and also, if I can figure out what that head unit plug difference is, what does that cable do and where does it got can it be altered or re-plugged?! Excuse my ignorance what is ACP/AA, what does that stand for? (Apple car play? Android air play)? so If I swapped head units to save using a band expander, I’d likely lose those better features to have an oem Unit operational. Better to use a band expander and retain AirPlay options and newer version of head unit     provably best to band expand it, and focus on the nav unit. th isn’t  a big deal/ would be cool to have it working  from what I can tel we use a PAL Signal and Japan uses a NTSC signal  I don’t know if there’s a co better or if the screen only reads NTSC, or if it’s the tv module that needs replacing… no big deal don’t need it but more of a curiosity thing on that!   Thanks for the info re tyre sensors, helpful and great to know.  I was reading the online manual off Japan website and it seemed to make it sound more confusing than it is  I guess a rim replacement would require the sensors to be moved to a new rim to carry that option over?!     Thanks for the info regarding diagnostic mode. I appreciate your help mate. Trying to brainstorm here to find a solution to get as much gadgets as I can working! I plan to get my local Nissan tech to have a look too who used to be at an Infiniti dealer back in the day to see if any thing they have or idea can find a soliton. But hoping anyone here has gone down the same route to make life easier!!   i guess identifying the cable/plug differences and what they do would be a great way of finding out if the units are transferable    thanks again
    • No idea about the remote start part. If the V37 nav is anything like other Nissan JDM vehicles, you can't get the factory Japanese nav working in australia, a card from a different car almost certainly won't work, those cards are usually matched to the serial number of the DCU.  You could be possibly swap out the components from a AuDM Q50 to get it working, but if this is a new model (2021+) 400R, then you will lose the newer features like ACP/AA.  That said, if you have ACP/AA, just use google maps.. I assume a band expander would be required to get the local radio stations, but don't forget the Japanese FM band is narrower than ours, so you still might not be able to receive all Australian stations. I can't see any reason the tyre pressure sensors won't work here, there is the sensor unit inside the rim and the receiver nearby in the wheel well.  I have never had to change the batteries on my 2015 Q50, so I assume they last quite a while.  A straight battery change shouldn't need them to be re-registered as they are the same unit, that should only be required if you replace a sensor with a new one.   Word of warning, if you ever go into the 'secret' diagnostics mode on the main screen, DO NOT EVER do a 'reset' in this menu, it will erase all of your model specific data in the DCU and you will need a trip to a dealer to re-program it all, which would be particularly painful being an import.  This applies to the AuDM Q50 too.
    • There is a known issue with the mix door motor on the Q50 which causes these symptoms, not sure if it is common on the Y51 though.
