I have two surplus blank key fobs, all you need to do is cut the key and pair it to your car following the key programming instructions.
These are old fobs circuits transferred to new shell+blade. I have done this and programmed one set of key to my M35 ARX. The battery voltage checks 3.4v which means its not flat.
The shells are not oem, but looks it. Only thing thats different is the rubber button is slightly lower then the original.
Key programming
Asking $110 per blank Key FOB - Delivered
I have excess shells+Blade also if anyone wants them.
Asking $12 Delivered via standard post.
https://www.sau.com.au/forums/topic/365495-m35-stagea-key-replacement/
looks like there is still some interests in getting the complete keys - I am in the process of putting more complete refurbed keys together in future for those that missed out. ie just - cut and program - for those that cant be bothered with the legwork/time/waiting/upfront $$$ etc.
Blades are the same profile, just finding the right innards is the hard part.
Will let you know when i have complete sets ready.
UPDATE
Hi Guys, the Keys FOBs finally arrived with my other parts.
Same price as before - $110 delivered ( will be sent via registered post ) I have check the battery voltage ( no battery are flat) and made sure that they all had the same part number ( K70206 C9923 0301 ) on the IC.
Hi Rez of IC of remote internal
The black chip is different on all (4144 093 211E) keys last four digits different, and the silver chip ( 31491 E240 ) is the same on all keys. So im guessing the black chip
makes each key unique. The battery side of the remote IC is all the same besides the four digit black marking.
** SIDE Note ** notice other Nissan cars used same shaped keys - not sure about internal or if they have transponders, all I know is that in japan they use 315mhz range for remotes - if you look closely at the IC, you will notice the 3rd button isnt solder on so im guess other keys may be Interchangeable with the Stagea ( wingroad, early Elgrande etc ) - but i dont have the money to find out.***
I can't really test the keys ( crazy for me to pair all the keys to my only car ) - unless someone wants to donate a spare key reciever module. ( happy to pay postage ) Theres no moving parts except for buttons and none of the rubber parts werent ruptured, and any signs of water in the keys. Buttons on the donor keys had your usual normal wear on the buttons.
I only managed to get 7 sets before I ran out of fund$ / those that have used external parties to get yahoo auctions parts do know how expensive it can get when you get carried away - first preference will go to the people listed in this order.
Unless they dont want them no more - I will offer to others if they pass thru.
jidge
tronzstagea x 2
bbenny
joshm35
spoolin12
bigkevracer
If for some reason you can not get your key to pair to your car, please PM me.
in process of sending PM's - will post pics tonight but it looks exactly as the ones in my first post.
Regards
Hue
works with the factory option alarm, ie if your car has a sticker and the two ultrasonic detectors ( one on dash and other usually mounted on middle pillar behind driver )
jidge - waiting for funds
tronzstagea x 2 No longer needs them
bbenny
joshm35 - waiting for funds
spoolin12 - Check PM
bigkevracer - No longer needed gone to bbenny mate.
So I have one left.
  • 4 weeks later...
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
