Hey Guys,
If you guys are like me you change your oil every 5-10K's and I know its not a big deal when it comes to draining your oil but I saw this valve which will make it just a little bit easier. Its not expensive shipping is cheap but since I'm going to order one anyway why not save you guys a few dollars, even more if we have a large interest, but otherwise if you like it you can just can go a head and order it otherwise if your intrested in a group buy show some interest and I'll organize something if we get enough people.
JR
Ebay Link
  • Replies 47
We only just ordered a bunch of these for the race cars. Handy little suckers...you'd think they would have been out decades ago? Don't doubt people have made their own custom valves over the years.
Wanna be careful with very low cars though...bashing the sump on a speed bump will probably be a bit easier and the consequences much worse...
That's awesome!
How many mm is the skyline thread?
According to this http://cgi.ebay.com.my/MAGNETIC-DRAIN-OIL-PAN-PLUG-SKYLINE-R32-R33-R34-GTR-/160501240692 12mm with a pitch of 1.25mm I will double check before I place an order too but the ebay link says F-103(12mm-1.25) fits
Nissan: 1990 & on all models(Sentra, Pulsar, Maxima, Stanza, Wagon, 200SX, 300ZX,Gas trucks, etc.)
Birdds you smart nutter you, yea I wanted to get the one with the nipple....giggidy....but they advised against it for low cars
quickvalveuk_634348360753400000-0.jpg <<< Thats the one...I thought I could be even more lazy by attaching a tube to it getting rid of the need for drain pans...buutt probably should just use the normal one
I'd probably grab one depending on price...
They are pretty cheap as is, I provided an ebay link if you want to get it yourself but this is just for us to save a few $$$
They are 100% M12x1.25.
I did the group buy for the Dimple drain plugs.
Thanks, I did lots of checking and research but it's always nice to have a confirmed perspective
I have one of these but im gonna remove it cause im really paranoid that something will hit it and then bye bye rb25.
Battery could you take some pictures and upload them to give us a better idea on how much it is actually protruding. Also do you have the one with the nipple or without?
yeah I would be too..
All you would have to do is run over a tree branch or something could knock it open..
Nice idea though.
Yeh ill try and get a pic on the weekend. Mine is very similar to the one in the first post except the lever has to be pushed in and then turned so it has a semi locking feature...
It is nice not getting your hands covered in oil and then spending 10 mins fishing the plug out of the oil pan lol.
I have also had the magnetic tipped plug which was great until it snapped at the bolt head!
If this is going to be a GB - please use the GB section and follow the GB requirements - we have em for a reason :)
That's awesome!
Until some asshat lets the oil outta your car in a carpark/driveway and then you are in the shit :merli:
    • Coming home late at night and driving past the police is the only reason i need one haha And yeh, definitley needs a switch to quickly enable it, dont have time to be getting my phone, opening an app, waiting for it to update etc before being able to make the change
    • Because it is financially convenient for them lol. Why wouldn't they want to give you the lowest possible valuation for your car?
    • Yep. @Duncan also shannons they will rip you dry and will be probably limited on how much you can drive. Also keep in mind that you always have to have it garaged with Shannons, with enthusiasts as per their PDS you can have it 2 times per week on the driveway for example.
    • I had a generic 4" Varex rear box on my old V8, worked a treat for sneaking home late at night, it was as quite as stock when closed The car was "fairly" loud when open as it consisted of 1" 7/8 headers to 3" catted Y pipe, to 4" single, it did have a resonator in the mid pipe and only the Varex out the back I also hard wired in a Varex dash mount switch, as the key fob thing is a pain to use when driving I wouldn't recommend giving the beans when it is closed though as it creates a large restriction in the exhaust  It also can in very handy when pulled over for "random" breath tests or just cruising past the constabulary
    • Here is the before and after of the scraping/sanding of the IC pads on the tachometer board for the fix mentioned in this thread. And yes it worked fine after. Just a note if you change any components on the board the tach calibration can be wrong showing the wrong idle etc...only problem is once it is installed back in the cluster you can't get to it to adjust...ouch! My fix was to cut out the calibration pot (the blue one) from the board and run it with two wires to the fuse panel under the dash where I could adjust the idle calibration once everything was installed. And yes I soldered everything up again including the half soldered components either side of the IC in my photos
