Need to get this done for my missus 180SX as well. Was useful for me... wanted to hit up Autobarn at Chadstone as the manager appears to be a fellow SAU member and the staff there are a helpful bunch
Just went to Supercheap and Autobarn, they both sell aero wiper blades for like $35-37 each....
So I think I'll be getting from somewhere else..
But I bought some Rain-X stuff tho lol
Oh also, do I need to use both Rain-X repellant and washer fluid additive for windscreen? Or is one of them enough?
If you use RainX I woudn't even bother with washer fluid additive, and like chuckie said, with RainX you can almost get away without wipers, it just beads and rolls off with any amount of speed
I find that RainX with silicone balde is awesome. I think the silicone blades were like $18 from Supercrap
Oh ok... Well I got some Rain-X 2 in 1 spray with glass cleaner & repellent ($15) and some washer fluid additive ($10).
Then I'll be getting a full set of aero wipers on the weekend, fronts & rear ($45), or should I just buy some cheap silicone refills from Supercheap?
Yer, not so sure the spray on ones are the go, just rainex in the small bottle. :thumbsup:
bosch twin aero is what i used on my GTT, great wipers.... 100% recommend
they look much better too and last for ages - i never changed them for as long as i had the GTT and they worked just as well at the end as they did at the beginning
i also clay/polish/wax or sealant my windscreen as well, can never have too much sheeting action on glass :D
Just an update guys. I bought a full set of silicone aero blade for $40 (like the Bosch ones), front and back.
And man.... They are AWESOME!
Because the aero blades are SO MUCH lighter than my old metal framed ones, they make absolutely NO noise while wiping, can't even hear the wiper motor!
And they don't leave any spots or streaks at all.
I'd definitely recommend them :D
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
