Hi Chris,
what problems are you having with the 4wd system. PS: I dont have it here with me at the office, so I cant check for you but there a thread where you can download the GTR Service manual in a PDF 800pages about 22Mb... if you dont have an answer I check it for you when I get home tonight.
https://www.sau.com.au/forums/topic/36557-gtr-hydraulics/#findComment-729629
Thanks guys. I have the R32 Service manual and it says 'Nissan Special Power Steering Fluid' which was a little unhelpful. I had removed the front drive shaft for a skidpan day and i'm no longer getting as much torque to the front wheels. So I was going to try bleeding the hydraulics and changing the transfer case oil aswell.
https://www.sau.com.au/forums/topic/36557-gtr-hydraulics/#findComment-729663
I also just had a GRID dash dancer installed by RevZone after this event, and it doesn't seem to be working in the 4WD mode (should be 50/50 split). The RWD works ok, but the 1st time I set it to 4WD the Active LSD and 4WD light came on in the dash and the car felt like the handbrake was full on. The car didn't want to move forward.
Now i'm getting the airbag and abs led comming on after about 15minutes of driving. But when I can put the car in neutral and roll along the led's go off.
So a few gremlins I need to sort out.
https://www.sau.com.au/forums/topic/36557-gtr-hydraulics/#findComment-729667
Yeah the special power steering fluid they refer to is Nissan Matic D. I had to go and buy some from Nissan when my car was apart, and the mechanic didnt put in enough fluid when putting it all back together.
Meshmesh, not yet. Ive got the redline lightweight shockproof for the gearbox and transfer case, and redline 75w90 for the diffs sitting right next to me as I type this :) Will let you know how it goes if youre interested.
https://www.sau.com.au/forums/topic/36557-gtr-hydraulics/#findComment-729690
So two litres is enough for gearbox and transfer case?
and I assume a litre each for the front and rear diffs?
The web site says MT90 for gearbox and trasfer case which is a 75W90, then says the diffs use a 75W90. There are 2 types of 75W90, the GL5+ and the GL4 (MT90) which one is correct?
https://www.sau.com.au/forums/topic/36557-gtr-hydraulics/#findComment-730113
You need two 3.785 litre bottles (1 US gallon) to do gearbox and transfer case. MT90 is reccomended for these then in brackets it has redline lightweight shockproof. Ive only heard good things about the shockproof, so went the shockproof. The 75W90 they sent me for the diffs is API GL5/GL6.
https://www.sau.com.au/forums/topic/36557-gtr-hydraulics/#findComment-730130
One 3.7 litre bottle should do both diffs. As told to me this is what the parts take
Gearbox -- 4.1 L
Transfer case -- 1.8 L
Rear diff -- 1.5 L
Front diff -- 1.0 L
I should be getting all those changed in the next week, if you havnt bought some by then Ill tell you how it goes :(
https://www.sau.com.au/forums/topic/36557-gtr-hydraulics/#findComment-730179
I rang the VIC rep from redline and had a chat. He says the price on the net is a little bit high for retail price and he told me to give Oil World in cheltenham a call as these are the closest stockist to myself. Will let you know how much of a saving I make. Might be worthing ringing around in the future. depending on your local area
https://www.sau.com.au/forums/topic/36557-gtr-hydraulics/#findComment-730250
    • More photos are up, and the price has been dropped to $16,000. It's just had a service and a new 12V battery, too.
    • I agree on doing some better than factory pistons, rods, and oil pump. For anyone using the vehicle on the road, I don't get why everyone wants big cams. The stock cam profile, with some more lift would be mint for road usage. Everyone going big cams and then wondering why it isn't as responsive in traffic, when they've shifted the torque curve upwards an additional 1000RPM. Make torque, at lower RPM. Sure it's not as cool as claiming "500KW" and revving it to 8,0000RPM, but that same torque 2,000RPM earlier... Then you don't need the extremely high end pistons and rods, and blah blah blah.
    • Personal experience. Those f**kers burn. And are actually a PITA to put out. Next time I walk down the back, I'll snap a photo of what the inside of the bonnet looks like when that thing ignites. PS, powder fire extinguishers are useless on that stuff too as it's fibrous and when it ignites, it starts to pull apart. And you end up just blowing powder through a sieve effectively.   Like the big thing is, if it's fire resistant, it's job is to stop what burning? The METAL above it? It's just to try keep heat off the bonnet paint work.
    • Oh man, sorry, $60.00000000... 😛
    • That's more or less what he meant. What it really means is that you do not have to go full crazy on the build. Don't need the best oil pump, expensive rods & pistons, big cams, etc. You can upgrade whatever you want instead of using stock level items, but you don't have to. Having said that - any time an RB is opened up, if anything is getting replaced, I think the opportunity should be taken to do all the sensible upgrades. Pistons, rods, pump, etc.
