I have fitted up one of the high octane kits which a customer supplied me with.
I'd rather do my own personally.
A reasonable pump, moroso, peterson, barnes etc will set you back about $1200 delivered now.
A new Peterson tank $450-800
Breather tank $150
Balancer with drive mandrel $800-900
Pump pulley $88
Belt $20
Sump $550-700
Heaps of people making brackets now days. I machine my own and normally sell them for $440
I think that's just under $4500 for the parts roughly.
I use earls hose and fittings. I have a very good relationship with the guys there and only use their gear.
Retail you can expect to spend about $4500-5500 for everything related to plumbing it up depending what size and type of fittings you use.
If you can find someone who deals with earls or mscn ( motor sport connections) then chances are you can do it alot cheaper.
Something that's worth mentioning is putting Filter/screens on all your scavenger lines as a bit of extra security, because if you do have a engine failure the pump will suck up the metal into your $1000+ pump and fair chance it will die aswell. I have them on my dry sump set up Peterson make them.
Something that's worth mentioning is putting Filter/screens on all your scavenger lines as a bit of extra security, ....
Damn good idea, even on a wet sump.
My sump designer knew this, but the engine builder didn't.....and I ended up with a broken bolt running on the oil pump gears.
Not being rude Mr Baron but I think it is hideous at $8k for what you get. It is convenient for a builder with more money and no knowledge or inclination to do it themselves but it is way out of most reach for most who don't want oiling problems.
That being said it is proven on the track!
This is exactly why I went the Hi octane kit first time around. Anything dry sumped up in Far north Qld was pretty much unheard of or restricted to big bore drag cars. I knew what I wanted but had nobody to help me out so the Hi octane kit was probably over priced for the parts you get but I had no other option and wasn't willing to gamble a new engine with something I had knocked up. I figure the price Hi octane charge is not that bad when you take into account the R and D that would have gone into it and I was happy to pay it on that basis alone. Plus the fact that I could bolt it on and know it was gonna work straight up was a selling point.
I have since helped out with mate's dry sump set ups. Just recently I've been helping build an Na SR20 set up from scratch for an Improved production 1200 coupe. I designed and milled the mounting brackets and helped with the sump from knowlage gained from my build.
I also got all my fittings from MSCN at wholesale prices which helped a heap. Did all the fuel system and oil system plumbing for under 3.5k.
How do you determine what size tank to run? I've seen things in boots the size of a keg and ive also seen tanks in the engine bay maybe only 5" diameter, is it determined by pump flow or is there a formula to calculate or bigger is better? what?
There is no science behind the tank that I'm aware of. Normally I'd make sure it's capacity is decent ( 7L minimum usually) and it's not too over kill.
I like Peterson tanks they have good baffling and oil control. Cheaper tanks tend to allow frothy oil to the bottom causing air in the pressure feed line. ( detectable with a clear hose temporaliy used during a dyno session.)
Most systems I do with a tank supplied by the owner I do a clear hose check on it. Just to be sure tank they bought works well. Do the same with any custom tanks I build
  • 1 month later...
    • No worries at all 🫡 I think the most satisfying things to make are the little bits that are just impossible to find or they're no longer manufactured. Generally I always try to replace parts with OEM wherever possible. This little project is also great because it'll never see the light of day, but strengthen these brackets so it's not just relying on the little standard screws in the headlight plastic. As soon as I saw the standard brackets and screws I thought, "well I'm not going to install with just the screws, the plastic tabs will just snap off". It's crazy how expensive everything has become yeah. But I suppose that's supply and demand; granted it's a lot easier to get brand new genuine parts these days which is fantastic 😊, I don't have to get totally reamed at the local Nissan dealer ha ha We sure are lucky we have all these manufacturers making parts these days, a few really great Australian companies too like Platinum Racing Products and Fit Mint Automotive, what a time to be alive ❤️ . I've got my eye on the RB26 head by PRP as mine has a very fine hairline crack, so that'll need to be addressed some time in the future. If you have any requests or odd things to make feel free to let me know and I can have a crack at making replacement parts ✌️
    • Thanks for sharing this, and BTW if your headlights are in good condition they are worth thousands....you might want to consider replacing them with brand new LED ones like this (https://www.nengun.com/78works/full-led-headlights-r32-skyline) and making enough profit to buy a house in Sydney
    • I'm not sure what sort of shops are nearby, but I'd expect any reasonable exhaust shop could put a cat in it that will not restrict the power that engine makes. Otherwise, if you want to remove it, short lengths that replace the cat are readily available online, search for "de-cat pipes" or "test pipes"
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
