I have fitted up one of the high octane kits which a customer supplied me with.
I'd rather do my own personally.
A reasonable pump, moroso, peterson, barnes etc will set you back about $1200 delivered now.
A new Peterson tank $450-800
Breather tank $150
Balancer with drive mandrel $800-900
Pump pulley $88
Belt $20
Sump $550-700
Heaps of people making brackets now days. I machine my own and normally sell them for $440
I think that's just under $4500 for the parts roughly.
I use earls hose and fittings. I have a very good relationship with the guys there and only use their gear.
Retail you can expect to spend about $4500-5500 for everything related to plumbing it up depending what size and type of fittings you use.
If you can find someone who deals with earls or mscn ( motor sport connections) then chances are you can do it alot cheaper.
Something that's worth mentioning is putting Filter/screens on all your scavenger lines as a bit of extra security, because if you do have a engine failure the pump will suck up the metal into your $1000+ pump and fair chance it will die aswell. I have them on my dry sump set up Peterson make them.
Something that's worth mentioning is putting Filter/screens on all your scavenger lines as a bit of extra security, ....
Damn good idea, even on a wet sump.
My sump designer knew this, but the engine builder didn't.....and I ended up with a broken bolt running on the oil pump gears.
Not being rude Mr Baron but I think it is hideous at $8k for what you get. It is convenient for a builder with more money and no knowledge or inclination to do it themselves but it is way out of most reach for most who don't want oiling problems.
That being said it is proven on the track!
This is exactly why I went the Hi octane kit first time around. Anything dry sumped up in Far north Qld was pretty much unheard of or restricted to big bore drag cars. I knew what I wanted but had nobody to help me out so the Hi octane kit was probably over priced for the parts you get but I had no other option and wasn't willing to gamble a new engine with something I had knocked up. I figure the price Hi octane charge is not that bad when you take into account the R and D that would have gone into it and I was happy to pay it on that basis alone. Plus the fact that I could bolt it on and know it was gonna work straight up was a selling point.
I have since helped out with mate's dry sump set ups. Just recently I've been helping build an Na SR20 set up from scratch for an Improved production 1200 coupe. I designed and milled the mounting brackets and helped with the sump from knowlage gained from my build.
I also got all my fittings from MSCN at wholesale prices which helped a heap. Did all the fuel system and oil system plumbing for under 3.5k.
How do you determine what size tank to run? I've seen things in boots the size of a keg and ive also seen tanks in the engine bay maybe only 5" diameter, is it determined by pump flow or is there a formula to calculate or bigger is better? what?
There is no science behind the tank that I'm aware of. Normally I'd make sure it's capacity is decent ( 7L minimum usually) and it's not too over kill.
I like Peterson tanks they have good baffling and oil control. Cheaper tanks tend to allow frothy oil to the bottom causing air in the pressure feed line. ( detectable with a clear hose temporaliy used during a dyno session.)
Most systems I do with a tank supplied by the owner I do a clear hose check on it. Just to be sure tank they bought works well. Do the same with any custom tanks I build
  • 1 month later...
    • Jump into the wasteland. Plenty of random posting/chatting going on in there.
    • I did not go to GTR Festival. It's quite a long drive and the car wasn't dialed in yet. I also wanted to see how the racing portion went before going. From what I can tell the classes were not heads up, index, or bracket - just whoever has the quickest ET wins. Never heard of that sort of thing before and maybe some people like it but it's not my cup of tea. I don't suspect I'll go if that is how the racing is done. I did get the car out three times and had issues each time. Some were my error - haven't raced the car in over two years - and others were parts. Had trouble getting the clutch to slip correctly and remembering how it was set up in the Haltech. Broke some drivetrain parts as well that couldn't be fixed in a couple days to get back out. Season definitely didn't end the way I wanted but at least the bearings are still fine! Not a fleck of material in the filter. Really hoping next year is the year I can actually test this car properly.
    • find it funny everyone claims different fuel chains, do different things with their fuel blah blah blah. We don't have that many fuel terminals in Australia. The fuel tanker trucks drive into the terminal, fill up, and drive directly to the service station and dump out. The majority of fuel you get, is coming out of the same terminals. The variation is actually at the individual service stations and how good their tanks are, as well as how much turn over they actually have. Older fuel stations, that haven't had their tanks replaced are going to end up with the worst fuel. Also a lot of older stations have shit design, and shit maintenance, and end up with more water absorption into the tank. This is when you then get a bad batch of fuel. Other shit things happen, like tanker drivers have a f**k up, and starting to unload the wrong compartment on their truck into the wrong tank.
    • Yeah go with that one
    • This one?? In other news: I cannot tell the difference between my red MX5 with the silver grey hard top......... and the Ferrari 599XX EVO, they might as well be twins, well.......apart from the big wang hanging off the back of the Ferrari...🤔🤣, without the wing they are identical
