I have fitted up one of the high octane kits which a customer supplied me with.
I'd rather do my own personally.
A reasonable pump, moroso, peterson, barnes etc will set you back about $1200 delivered now.
A new Peterson tank $450-800
Breather tank $150
Balancer with drive mandrel $800-900
Pump pulley $88
Belt $20
Sump $550-700
Heaps of people making brackets now days. I machine my own and normally sell them for $440
I think that's just under $4500 for the parts roughly.
I use earls hose and fittings. I have a very good relationship with the guys there and only use their gear.
Retail you can expect to spend about $4500-5500 for everything related to plumbing it up depending what size and type of fittings you use.
If you can find someone who deals with earls or mscn ( motor sport connections) then chances are you can do it alot cheaper.
Something that's worth mentioning is putting Filter/screens on all your scavenger lines as a bit of extra security, because if you do have a engine failure the pump will suck up the metal into your $1000+ pump and fair chance it will die aswell. I have them on my dry sump set up Peterson make them.
Something that's worth mentioning is putting Filter/screens on all your scavenger lines as a bit of extra security, ....
Damn good idea, even on a wet sump.
My sump designer knew this, but the engine builder didn't.....and I ended up with a broken bolt running on the oil pump gears.
Not being rude Mr Baron but I think it is hideous at $8k for what you get. It is convenient for a builder with more money and no knowledge or inclination to do it themselves but it is way out of most reach for most who don't want oiling problems.
That being said it is proven on the track!
This is exactly why I went the Hi octane kit first time around. Anything dry sumped up in Far north Qld was pretty much unheard of or restricted to big bore drag cars. I knew what I wanted but had nobody to help me out so the Hi octane kit was probably over priced for the parts you get but I had no other option and wasn't willing to gamble a new engine with something I had knocked up. I figure the price Hi octane charge is not that bad when you take into account the R and D that would have gone into it and I was happy to pay it on that basis alone. Plus the fact that I could bolt it on and know it was gonna work straight up was a selling point.
I have since helped out with mate's dry sump set ups. Just recently I've been helping build an Na SR20 set up from scratch for an Improved production 1200 coupe. I designed and milled the mounting brackets and helped with the sump from knowlage gained from my build.
I also got all my fittings from MSCN at wholesale prices which helped a heap. Did all the fuel system and oil system plumbing for under 3.5k.
How do you determine what size tank to run? I've seen things in boots the size of a keg and ive also seen tanks in the engine bay maybe only 5" diameter, is it determined by pump flow or is there a formula to calculate or bigger is better? what?
There is no science behind the tank that I'm aware of. Normally I'd make sure it's capacity is decent ( 7L minimum usually) and it's not too over kill.
I like Peterson tanks they have good baffling and oil control. Cheaper tanks tend to allow frothy oil to the bottom causing air in the pressure feed line. ( detectable with a clear hose temporaliy used during a dyno session.)
Most systems I do with a tank supplied by the owner I do a clear hose check on it. Just to be sure tank they bought works well. Do the same with any custom tanks I build
  • 1 month later...
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
