This thread needs some photos for those who dont get to see many dry sump setups or have never seen one.
Sorry the photos are not the greatest quality but they do show the dry sump.
Its a tight layout with a 5 stage system. These are of an RB26 in a GTR
And the boot with tank and some of the breathing system.
It is a pretty well sorted car, the owner has put alot into it.
The mentality has been, right way or no way from the beginning.
A few things still to change and tidy up, if I was to build another GTR for myself I'd use alot of the same componentry.
cool, ill have a hunt around for some pics.
unrelated to the dry sump topic but still oil related, I'll be giving you a bell re: a extended sump for my Soarer...just gotta check I can get the pan off with the motor in the car and how much room I have
The pressure stage is usually at the rear of the pump, it's a separate section that's sealed from the scavenger stages.
It's normally at the rear so the rear bearing plate can incorporate a pressure relief valve.
The new Peterson range also have a bypass valve that returns the excess pressure into the scavenger stage instead or returning it to the inlet of the pressure stage.
There are for and against for both types but the new petersons seem to work okay.
Mike I'll send you a different number you can get me on now.
  • 1 month later...
Very nice choice.
In the next few weeks I'm hoping to test out one of my "behind closed doors projects"
An integral pump/pan with internal scavenging galleries using a similar Dailey pump that mike is using.
Working on the drive system still which will be via a multi row chain internally from the unused factor pump drive section of the crank.
  • 3 weeks later...
    • If you are keeping the current calipers you need to keep the current disc as the spacing of the caliper determines the disc diameter. Have you trial fitted the GTS brakes fit on a GTSt hub or is this forward planning? There could be differences in caliper mount spacing, backing plate and even hub shape that could cause an issue.
    • Hi there I have a r33 gts with 4 stud small brakes, I'm going to convert to 5 stud but keep the small brakes, what size rotor would I need?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
