Looking at getting some Porsche Carrera cup front slicks on the GTR, but was wondering what kind of effect would it have on a non uprated sump. As I know it, mine is standard so the last thing I want to do is destroy the engine from an oil surge. A couple of track here in the UK I would avoid as they have have fast corners that go on for more than 4 seconds..
I have been hearing a few things of dry sump setup for an RB, but have not seen much about the kit itself or the costs.
Dry sump is ideal but megabucks (google for examples) . You can get a bigger sump with gates and baffles and for the Link/Vipec and possibly other ecus you can get an oil pressure cut out switch to cut the engine when oil pressure is inadequate for the rev range.
nb I hope you are going to get 4 slicks and not just 2
Do you have the suspension adjustment to make use of the slicks?
They aren't like normal semi comps or street tyres. If you have a stock sump im guessing you might not have such adjustments.
There is a thread in the Motorsport section about slicks, have a read of it.
Ah i was talking thing like camber etc, you need MUCH more than you would run on the street.
Have a read of the MSport section, you really won't get much benefit of slicks by the sounds of your setup and would be far better off with semi's.
    • In all the track days I've done over the past few months I've only had 1 issue with braking and thats with my current EBC pads (can't remember the colour, but they're not a track pad). I don't *think* I have had issues with brake fluid getting too hot, my understanding is that when that happens you will have quite noticeable brake loss - which I haven't had.  I'm using just regular ol' Penrite Super DOT4 fluid. I use this fluid in everything and my cars always seem to stop so I see no reason to change, except ... for the 335i. I need to do a fluid flush and was thinking about my fluid of choice and wondering if I should consider using something more high temp? Its not a super fast car by any standards but I'd hate to do a flush and then find myself with no brakes when I get. to Wakefield.  I guess, my question can be summed up as "How fast do you need to be driving to need higher temp brake fluid?"  I remember high temp fluid was considered a must have back in the day when I had my GTR.
    • For anyone that comes here looking for answers on what can go wrong with gts-4 to rb25detneo swap. The Gloria's awd sump is different and does not fit. The rb25neo from stagea are exactly the same sump bolt pattern and axel alignment. Castings numbers are different on Gloria's blocks and oilpans if they need to be identified.
    • I have information on this for anyone that comes looking again. https://www.facebook.com/share/p/18gsbFaYTU/ The rb25det neo from the stagea has the same sumo as rb26 and r32 gts4 (and other awd models). The sump that has caused so many problems during swaps are from the awd neo Gloria's. The casting numbers on the block and oil pans are different so this may help identify if you can't confirm where the motor came from
    • Not feasible to fix the boot lid you had? Damage looked minor/hard to even see :p Source: Drove into something recently and you should be happy you didn't!
    • Another new used boot arrived at the painters, it was sent back as there was nearly as much damage as the original one I want to replace  Finding a clean used boot lid is proving problematic, and I'm not keen on dropping $1500 on a new one from Mazda Sigh....
