car inspection
Guest neoGT-25
Hey all :)
I have found a nice A31 NISSAN CEFIRO for sale... only problem is, im in qld :D
now, before i buy her, i want to get it inspected and possibly compression tested (are compression tests worth doing & how much?) Since im in qld, i wouldent have a clue who to get it tested by and i have heard that RACV arnt very good with import inspections??
could someone please give me an idea of who to go to? web-links? phone numbers? anything like that! ;)
please please please help!! :wavey:
thanks, Cameron
ps: yes my speeling is bad, thats cost its 9:37am :)
https://www.sau.com.au/forums/topic/36562-car-inspection/
Its in QLD .. RACQ up here will do inspections, but same problem as VIC in that they might not fully know imports. It will be expensive also if you are not a member. Could try giving them a call, and they'll be able to fax you the results of the test.
Compression test is the same procedure no matter what vehicle, but its just a bitch of a bitch on the RB20's as you gotta pull a few bits off which they don't like doing.
The number for their bookings service is: (07) 3361 2700
https://www.sau.com.au/forums/topic/36562-car-inspection/#findComment-729863
`read it again u qld pig traitor
edited so he didnt think i was talking to him and being rude :(
https://www.sau.com.au/forums/topic/36562-car-inspection/#findComment-729872
lol.. you want a drift car don't you?
At $9k -- even with an autoconversions would be a good deal if you ask me.. at the time you can also get the RB25DET box put in which will be heaps stronger anyhow. I'd say at a guess the fuse would be possible as it uses a similar ATESSA system to the R32 GTR from what I've read.
https://www.sau.com.au/forums/topic/36562-car-inspection/#findComment-730180
Guest neoGT-25
i see
i will look into it!
problem is... the one i found in melb has much better bits... inc a 2way mech lsd, manual conversion, heavy duty clutch, hks pod, turbo timer, strut brace, drift wheels (16"), 2x cat back zorsts (one mild steel, one stainless) droped on springs too...
byes :(
https://www.sau.com.au/forums/topic/36562-car-inspection/#findComment-730276
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
    • Brumbys with good shells are bloody expensive, I've looked at 2 "cheaper" cars, and walked away from both,  plus after some research spare parts are fairly sparce I'm starting to think that I missed the boat on finding a clean one that is straight (ish) and without alot rust I'm starting to think about a old Hilux as panels and other parts are much more available as they sold tens of thousands of them I use to be indecisive but now I'm not sure
    • A Brumby would probably fit a big metal toolbox in the back... this is how it begins
    • Picked up a new OEM boot seal for the MX5 today as the old one got ripped a bit by me being a idiot by seeing if I could fit a large metal tool box in it, it didn't fit, and ripped the seal with the corner of the tool box I am still waiting on time to get the cams and new balancer installed, as well as the repairs to the boot Time will not be an issue soon though
